Old 02-10-2012, 08:03 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
What can they take?
Would an NV4500 hold up behind a 390hp/445ft/lbs 383 SBC? Mind you this is hammer down and plenty of clutch dumping and maybe some power-shifting, and in a suburban. Same question for a 14BSF. Both being regularly maintained of course. Thanks, Bradley
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-10-2012, 11:46 PM   #2
Mattman2010
Mattman2010's Avatar
Re: What can they take?
From what it sounds like you need to buy a car. If you plan on doing all of that in a suburban you probably need to rethink that. Suburbans are not a light vehicle, and most of what you are wanting to do is just asking for trouble. As for what you are wanting to do yes a NV4500 will hold up. Clutch dumping will more than likely depend on the clutch you use, but you will more than likely break something or need to replace your clutch a lot. As for power shifting, the nv4500 is a truck transmission. You wont be power shifting with one of those. So like I said if you want to be doing all of that you are better off finding a car with a manual transmission.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 02-11-2012, 01:24 AM   #3
joe231
joe231's Avatar
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-11-2012, 08:57 AM   #4
thirdstreettito
Resident of Here
Thanks guys, looks like a 4L80E is in my future. If I wanted a car I'd have bought a car.
~Bradley~
Miss having a truck
Old 02-11-2012, 10:49 AM   #5
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
In all honesty , If you engine has those specs ( 390hp/445ft/lbs 383 SBC ) dumping the clutch would never need to happen .
Quote from the drag strip years ago " If you want to work on it , Put a manual tranny in it . If you want to race it use an automatic .
The weak link in the 14 bolt (at least for me ) is the spider gears . Bombed two sets in a dedicated mudder with a rock solid shifting 350 turbo .
If your in a 4x4 the front axle with be the next problem . Your going to need a good source for parts . in 3 years I lost 3 inner shafts and 5 outer shafts . Spiders exploded . Strangely enough I never lost a driveshaft U joint .
powerdriver 1958 is offline   Reply With Quote
Old 02-11-2012, 11:04 AM   #6
thirdstreettito
Resident of Here
Thanks pd! Would you put in a full manual 4L80 or buy the computer and do the 4L80E? It doesn't matter to me.
~Bradley~
Miss having a truck
Old 02-11-2012, 11:17 AM   #7
powerdriver 1958
Kid's Mechanic
Is this a daily driver or a play rig?
Old 02-11-2012, 11:38 AM   #8
70custom20
70custom20's Avatar
That quote is pretty much correct from years ago. With clutch and pressure plate technology of today, it isn't so true anymore. I have a manually shifted drag car that doesn't break anything. With that being said, I wouldn'd do what thirdstreettito had originally posted about clutch drops/ flatshifting an NV-4500 in a suburban. That type of abuse in a truck that heavy would definitely have broken parts at least as long as his wallet could handle it.
70custom20 is offline   Reply With Quote
Old 02-11-2012, 04:29 PM   #9
Nothing can take abuse for long...in anything. The NV4500 shifts fast and smooth,nothing like truck 4spds. Yet the throw is long,nothing like a car 4spd. In my experience an NV4500 can't take nearly what the SM435 and 465s can take. I use them in my work trucks and have had to replace/rebuild three. I haven't had one go much over 100,000 miles and that's with regular oil changes. I've never had a 4spd go up on me and they were all in trucks that who knows did what before I bought them.
Old 02-11-2012, 07:45 PM   #10
Zoomad75
K5Camper
Zoomad75's Avatar
DirtyLarry's running around with a high hp/tq 8.1L big block/nv4500 in his 78 K10. It's putting out more hp/tq than your 383 small block for sure. The trans does fine. Yes it shifts better than a dump truck 465 muncie, but it is by no means a speed shifting gear jamming car transmission. Driving by dumping the clutch is just going to be hard on any trans. Not to mention the abuse to the drivelines and the diffs. A semi-floating 14 bolt is going to leave you on the side of the road or trail if those tires have traction and it snaps one of the c-clip axles.
It's your rig and you can do with it what you want though. A 390hp 3/4 ton sub still isn't going to win many drag races anyway if you plan on beating it to death.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 02-11-2012, 09:47 PM   #11
thirdstreettito
Resident of Here
Both
Thanks, I figured I should go full float with that weight and power.
~Bradley~
Miss having a truck
Old 02-12-2012, 01:05 PM   #12
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea I know some people with built motors running NV4500s but not in any suburbans haha. 4l80e seems like a better route to go for your needs though!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-15-2012, 11:09 AM   #13
Mr. 250r
Mr. 250r's Avatar
I like my stock 4l80 setup in my suburban and I abuse it but not by brake torquing more like going through mud and throwing it in reverse quick and it grinds and did it a few times also dropped in reverse and rev'n to where it was screaming many times and ripped the wiring out and lost over drive for awhile but still going good but I don't recommend what I did because I wasn't allowed to get stuck only reason I did it but soon it will be abused by a 6.0 hopefully it holds up as for the semi floater yes it has c clips but I haven't seen a rear axle break not saying they don't but if you wanna get by for a while to save up for a FF i think it'd be fine
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold
2003 1500 Silverado - Selling
2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LB SRW
Mr. 250r is offline   Reply With Quote
Old 02-15-2012, 11:15 AM   #14
Semi-floaters have been good axles for me. I'm a full-floater guy from way back...had them in most of the trucks I've owned. I've had semi-floaters in three vehicles with no problems. I always intended to swap in full-floaters and never did. The truth is,I never needed to...apparently. Never heard any issues from others,either. I just like the bigger stronger stuff...by choice and perhaps not necessity. I have a semi-floater in my Jimmy and I will say it's big and bad compared to a 12-bolt.
