Old 02-11-2012, 10:56 PM   #1
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
Who is using electric fans?
Okay... looking to put on a dual elec cooling fan setup on my 86. I am looking for pics and general specs of ones that are built or even complete kits that are setup for these trucks. I think we can all buy some fan and wire it up, however I would like to have something a little more "meant to be there"
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 02-11-2012, 11:12 PM   #2
85burb
85burb's Avatar
Re: Who is using electric fans?
I am using this fan set up came with fans shroud and rad. They work great. Very happy with them. If you get duels make sure you run them with there own fuse and relay perfan. I found that out the hard way. Got the hole kit off ebay for under 400.
http://www.ebay.com/itm/ALL-ALUMINUM...item3f1105cb3a
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-11-2012, 11:20 PM   #3
stueber68
stueber68's Avatar
That is a nice kit. I do however have a brand new radiator already, but I can see if the sell the fan/shroud setup by itself.
Old 02-12-2012, 12:04 AM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
I wanted a conversion that looked basically stock as well, I'm going with this set-up on Project 74; http://67-72chevytrucks.com/vboard/s...d.php?t=254617
I doing the same on my 97 in a few weeks, Looks stock and won't break the bank.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-12-2012, 06:35 AM   #5
ttcunn
ttcunn's Avatar
I had an 83 once with a 400 sb, my ac guy hooked me up with the install and connected it with a switch that kicked on the fan at either rising temp on the 400 or 300 lbs on the high side of the ac. Worked great!!
2012 Harley Ultra Classic (Daily Driver)
1970 Mercedes 250C ( when its wet) For Sale
!982 Chevy Scottsdale SWB (in Progress)
ttcunn is offline   Reply With Quote
Old 02-12-2012, 04:24 PM   #6
stueber68
stueber68's Avatar
restrob... that will be a cool setup for your truck. Problem that I have right now is I don't have a V8 fan shroud for my truck. Just have the V6 one from the motor I took out.
ttcun... I will actually need to add a high pressure switch to my system since all it has on the high side right now is a pressure relief valve. Good suggestion.
Old 02-12-2012, 04:58 PM   #7
stueber68
stueber68's Avatar
Well... I searched through google images and found this one that I liked. Just so happens another member had done this. It is not quite as "factory" looking as I would like to see but really slick none the less.
http://67-72chevytrucks.com/vboard/s...d.php?t=216128
Old 02-12-2012, 06:45 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
84 GMC with a 383 stroker and electric fans mounted behind a Be Cool aluminum radiator. I also had the same fans on my 91 Silverado for daily use.
Frank
Old 02-12-2012, 06:55 PM   #9
stueber68
stueber68's Avatar
okay piecesparts... where are those from?
Old 02-12-2012, 07:09 PM   #10
piecesparts
The fans are made by SPAL and they are sold as a dual 11" fan kit, which includes the shrouds. I mounted the fans using aluminum bar stock, purchased from my local hardware store. It ies easy to work with and is not extrremely expensive. I mount the fans right up close to the radiator fins, but not touching them.
Try searching on the net for sources. http://www.google.com/products/catal...d=0CFAQ8wIwAg#
Frank
Old 02-12-2012, 09:39 PM   #11
Stew_Magoo
I plan on looking into putting Lincoln Mark 8 fans in my truck.
Stew_Magoo is offline   Reply With Quote
Old 02-13-2012, 02:12 AM   #12
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I run dual LS1 fans on my truck.
This year, I'm upgrading!! I'm going to a killa fan Mark VIII!!
I'm going with a 454 shroud as the mounting frame. Basically this setup.
http://www.off-road.com/trucks-4x4/p...oject1580.html
I'll be using the low speed for A/C. Full speed for engine cooling.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-13-2012, 12:15 PM   #13
1beatnik
1beatnik's Avatar
Please use a Spal or major auto makers product, lots of cheap junk out there. I run a Spal and had to learn the hard way the first time, 600mi from home fan took a dump and no auto parts stores open or the ones that were didnt have anything or any idea. So I bought a regular fan to get me to Shades of the Past then found a Spal, and has worked great for me since.
1beatnik is offline   Reply With Quote
Old 02-13-2012, 08:45 PM   #14
gchemist
gchemist's Avatar
More info on the Mark VIII fan.
http://www.fordmuscle.com/archives/2006/10/Mark8Fan/
Other great OE fans include Honda, Chrysler Jeep and Viper.
Old 02-14-2012, 01:59 AM   #15
rayfinseats
I run junkyard dual electric fans on my 83 350. ($25) wired to ignition on switch, w/ relay direct to battery. Never goes over 180. Takes a while to warm up though. Any factory V8 fan will probably work. If you use a switch don't forget to turn it on...
rayfinseats is offline   Reply With Quote
