Old 02-12-2012, 05:33 AM   #151
nibs
JRods Garage
nibs's Avatar
Re: Getting Started
You may have already said this, but what accessory drive setup are you planning on running?
Orange Julius-My dropmember'd, LS'd, SWB street machine...
nibs is offline   Reply With Quote
Old 02-13-2012, 10:58 PM   #152
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Planning on ordering the Concept One LS system pretty soon. Any suggestions...
RCC
BigShoe24 is offline   Reply With Quote
Old 02-14-2012, 05:29 AM   #153
nibs
JRods Garage
nibs's Avatar
Re: Getting Started
Nah, I was just trying to see what everyone else is using with their dropmember... I did run across this system the other day. Quite affordable to some, and I think it looks really nice
Old 02-14-2012, 10:16 AM   #154
Hart_Rod
Hart_Rod's Avatar
Re: Getting Started
That's pretty sweet. What was the price?
Hart_Rod is offline   Reply With Quote
Old 02-14-2012, 01:00 PM   #155
nibs
JRods Garage
nibs's Avatar
Re: Getting Started
Actually not bad at all. Check out their website for pricing according to what items you want. Apparently they have it polished as well
Ventura Speed Center
Old 02-14-2012, 03:38 PM   #156
67cheby
67cheby
67cheby's Avatar
Re: Getting Started
man truck is looking TOP NOTCH !!
67cheby is offline   Reply With Quote
Old 02-14-2012, 10:53 PM   #157
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
I was wondering if anyone could help me out on how I might shorten the length of my steering shaft? I have noticed many others have a shorter shaft, no pun intended.
Can I replace the shaft, or cut it and redo the spline? Neither option sounds very simple. Thanks,
RCC
Old 02-18-2012, 04:46 PM   #158
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Ok, I am wondering if this U joint might solve the need for running two, rather than three?
RCC
Old 02-18-2012, 04:50 PM   #159
67cheby
67cheby
67cheby's Avatar
Re: Getting Started
i am only running two single ones
Old 02-18-2012, 06:22 PM   #160
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Here is a shot that shows my issue. I think if my shaft (out of steering column) was three inches shorter I would be able to run only two joints? Any suggestions?
RCC
Old 02-18-2012, 06:36 PM   #161
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
67cheby,
Your set up is ideal, but I need to figure out how to shorten the output shaft on the steering column.
RCC
Old 02-18-2012, 06:39 PM   #162
67cheby
67cheby
67cheby's Avatar
Re: Getting Started
hmmmmm...i see
Old 02-18-2012, 06:40 PM   #163
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Couple more. I got my brakes all done and am hoping to get an accessory kit soon. Very soon
RCC
Old 02-19-2012, 11:20 AM   #164
nibs
JRods Garage
nibs's Avatar
Re: Getting Started
I guess I dont understand where your issue with the steering is?
Old 02-20-2012, 01:15 PM   #165
Nova_Cobra64
Nova_Cobra64's Avatar
Re: Getting Started
Where do you plan on mounting the fuse panel and ECM? I assume in the cab with as clean as that engine bay is going to be?
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 02-20-2012, 01:20 PM   #166
Splash4195
Re: Getting Started
Nice Build!
Splash4195 is offline   Reply With Quote
Old 02-20-2012, 01:22 PM   #167
PBFAB.COM
PBFAB.COM's Avatar
Re: Getting Started
Originally Posted by BigShoe24 View Post
67cheby,
One option....
On the 60-66 columns the shaft is a 3/4 round shaft. We send a DD joint and have the end user grind two flats on the shaft for the DD joint. It is important to take your time to ensure a good fitment, but this provides a better union than running a shear pin.
You could cut your shaft down a couple inches and do this same modification.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-22-2012, 10:56 PM   #168
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Nate, excellent call. I assume if I shorten it 2.5" to 3" I can get by with running only two joints. I don't have any clearance issue and I looks the cleanest in my opinion. Thanks again.
RCC
Old 02-22-2012, 10:59 PM   #169
67c10rustbuket
67c10rustbuket's Avatar
Re: Getting Started
WOW thats one sexy truck!
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
