Old 02-14-2012, 08:54 PM   #51
webfoot
Re: 71 K-20 tow/haul truck
I ordered the code 522 basecoat today. I already have all the other stuff. Now still waiting for spring so I can DD the chevelle.
In hindsight I wish I had kept those old wagon wheels and tires so I could leave them on for paint.
Slowly piecing together all the trim too. Still need 1 upper fender spear and both bed pieces, and several of the lower.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 02-14-2012, 09:18 PM   #52
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice! Are you looking for NOS or just good used stuff?
Ryan
1969 Chevy milk truck
Old 02-14-2012, 09:32 PM   #53
webfoot
Good used, although all I have so far is new but that was not my original intent. Ended up lucking out on an ebay auction which ended on christmas. Got 1 NOS fender spear and 2 NOS door trim (all upper) for about $90 shipped.
-me
Old 02-21-2012, 01:30 AM   #54
webfoot
I started thrashing through the steering components yesterday. Today was crappy and raining. Got the new steering box installed, that can be a bear by yourself. The old one was very sloppy, but not surprising since I believe it to be original. Removed the center link to install new tie rods. Since I already had that inside I also cleaned it up and painted it.
I have been storing a friends power washer and that made it about 1000 times nicer working under there without all the caked up mud and grease.
Most of the upper and lower trim is now on its way too. I think i am missing 3 small pieces and that is all.
-me
Old 02-21-2012, 01:54 AM   #55
litew8
litew8's Avatar
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 02-21-2012, 09:44 AM   #56
Dieselwrencher
Sounds like great progress!
Ryan
Old 02-27-2012, 06:40 PM   #57
webfoot
I got all the above mentioned steering parts installed. Drives like a new truck now! I can hardly believe it. Also installed a new rag joint and even had a chance to clean & paint the drag link.
Paint and trim are here, c'mon spring! I suppose I could start drilling out spotwelds on the old rusty rocker panel since it has to be providing about 0 structural support at this stage in its life.
The truck always had some aftermarket front sway bar until I recently removed it. It bolted to the leaf springs. I have not noticed one bit of difference without this installed. It has a rear sway bar too.
-me
Old 03-04-2012, 11:03 PM   #58
webfoot
Some more progress today, here is a good shot of the driver's side rocker:
Inner is not too shabby!
Cleaned it up and shot a few coats of epoxy primer on it. I still have 2 or 3 spotwelds I couldn't get to, so it looks like I'll have to remove the fender. Anybody know how big of a pain this is?
-me
Old 03-04-2012, 11:34 PM   #59
VA72C10
VA72C10
VA72C10's Avatar
looking good! That inner is nice for an original...
What about just unbolting the lower mounting point of the fender...should let you get to the spot welds...
Old 03-05-2012, 01:03 AM   #60
webfoot
I'll give that a try, thanks for the tip.
-me
Old 03-05-2012, 10:49 PM   #61
webfoot
Today I installed a headlight relay kit. It really makes a nice improvement over stock. But it is still 2 daggers of light in front of the truck so now that I have the relays installed I will try out the H4 upgrade.
I removed the bottom fender bolt and the next one up which attaches to the inner fender and that fender would not budge so it sounds like I'll be removing the fender to finish this job. I need to replace the bottom of the kick panel and a little of the floor next to it so it will wait. Parts ordered!
I really need to get working on that GTO again. These projects have got me back in the spirit again. Luckily the rust is gone from the goat and it is sand bondo time.
-me
Old 03-06-2012, 06:17 PM   #62
Dieselwrencher
Sounds like nice work getting done. What H4 upgrade are you going with? My brother just did a 6k HID bixenon kit on his dodge, and I think I'm going that route.
Ryan
Old 03-06-2012, 06:59 PM   #63
webfoot
Probably just the cheapie upgrade. I've noticed that if you look on ebay at the ones for 71-72 chevelles they are much cheaper than the ones listed for trucks. A 7" headlight is a 7" headlight.
-me
Old 03-06-2012, 11:56 PM   #64
Dieselwrencher
There are a lot of ugly ricer stuff on there too! I don't want a halo ring or turn signal in it.
Ryan
Old 03-07-2012, 04:27 PM   #65
webfoot
You aren't kidding. They come up with some real gaudy stuff but hey, apparently it sells. To each their own.
I have a benchtop sandblast cabinet on order which will be here tomorrow. I am looking forward to removing parts/brackets and painting them. The weather is starting to get nice so I will probably blast the wheel wells (outside) too.
-me
Old 03-23-2012, 11:38 AM   #66
webfoot
I got the rest of the old rocker off. 3 quick spotwelds were all that was left. Now that I have been under the truck again I see that moving the lower leg of the fender back is and would have been the preferred method but I did not know there was another bolt on the back of it! So I removed 15 bolts and still couldn't remove the fender and ended up using that method anyway.
New rocker panel should be welded in today sometime. I am very happy with the fit of it.
-me
Old 03-25-2012, 08:56 PM   #67
webfoot
Success! Turned out great. The rocker doesn't really lay flush with the rear part of the cab but what do I expect for a repro taiwan piece.
-me
Old 05-13-2012, 09:35 PM   #68
webfoot
My truck finally fits in Eastern Oregon. I bought a gun rack.
-me
Old 05-13-2012, 10:04 PM   #69
RINC
RINC's Avatar
Sweet ! I needs a gun rack too !
Chris
'69 C-20
'04 Jeep TJ
RINC is offline   Reply With Quote
Old 05-14-2012, 03:51 PM   #70
Dieselwrencher
That is funny stuff!
Ryan
Old 05-14-2012, 03:56 PM   #71
webfoot
Turns out the guy who posted those didn't actually have them anymore. No matter since I found brand new ones for less on amazon.
Amazon.com: Allen Company Metal Gun and Tool Rack... Amazon.com: Allen Company Metal Gun and Tool Rack...
-me
Old 05-14-2012, 07:14 PM   #72
Tinkermc
truck looks very nice
Tinkermc is offline   Reply With Quote
Old 07-29-2014, 07:11 PM   #73
webfoot
Well, one final update. Almost 2 years ago we had our first child, and the 71 being my only truck it was time for an upgrade. (I got a 2005 2500HD quad cab with the 8100 vortec, it loves gas almost as much as the 71 does)
The truck has mostly sat for the last 2 and a half years and it is finally time to part with it. A guy from CA is taking the bus up and will drive it home, almost clear down to L.A.!
Now I got hunting for a new project - going to look at a 59 bel air.
-me
