Old 02-16-2012, 12:02 PM   #1
ozzyman
ozzyman's Avatar
Question New 66' 3/4 ton project ?'s
Hey Just joining the forum and I'm getting a start on a 66' Chevy Pickup 3/4 ton fleet side long bed C20. A little history my dad purchased the truck in 1969 used with 15,000 miles and put a camper on it a decade or so later. We used it for camping as I grew up as a kid until we upgraded to a full motorhome. At this point we pulled a set of 1 ton springs from under it as well as a set of hellwigs changing it back to 3/4 tons springs and pulled the camper off. I drove the truck from ages 16-20 until I joined the Air Force. I finally have an opportunity to begin working on this truck and will be headed to southern Cal to pick it up in a few months. This truck is fully operational and used occasional to pull loads and what not. it's equipped with a stock 327 with 98k original miles and a 4 on the floor w/ granny low.
I'm beginning to gather parts for the resto. First step I want to get rid of the Eaton rear end with 4.57 gears. So I picked this puppy up yesterday for $100 w/ 3.73 gears
This is a gm 14 bolt FF out of a early 70's pickup. I will be pulling it apart and rebuilding what needs it.
My question for now is can someone point me in the right direction for mounts to use? My understanding is the 14 bolt has slightly larger axle tubes and the eaton mounts wont cut off and swap over.
Also looking at the flange mount/yoke on here it is 4 bolts with 2 "straps". any clue what modifications to my drive shaft i will have to make?
Thanks!
Mike
ozzyman is offline   Reply With Quote
Old 02-16-2012, 12:54 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: New 66' 3/4 ton project ?'s
Captain Fab has mounts for the trailing arms.
Check out my 66 Service Truck thread.
(My signature link)
those 2 straps fit right over the u-joints just as the the u-bolts. No mod needed there.
Thanks!
Mike
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-16-2012, 01:00 PM   #3
LostMy65
LostMy65's Avatar
Here's where I made the swap on my 66;
http://67-72chevytrucks.com/vboard/s...99#post4705699
Old 02-16-2012, 01:11 PM   #4
ozzyman
ozzyman's Avatar
Thanks! Awesome thread and exactly what i was looking for. Did your pan hard bar and mount swap over? the pic in post #88 isn't showing up for me at work.
Old 02-16-2012, 01:22 PM   #5
LostMy65
LostMy65's Avatar
Yeah, I just learned recently that a lot of companies block photobucket on work computers.
I welded the eaton's panhard bar mount to my 14bolt. Fit nice.
Old 02-16-2012, 01:30 PM   #6
ozzyman
ozzyman's Avatar
Awesome Thanks a ton for the info, looks like I'll do mine the exact same way. I really like the jig you made up, I was planning on bolting mine up to the truck to get placement and spot weld in place but the jig looks like a great idea.
Any mods to your drive shaft needed?
Old 02-16-2012, 01:35 PM   #7
LostMy65
LostMy65's Avatar
No mods needed to mount up drive shaft.
Still plenty of travel at the yoke there at the carrier bearing.
