Old 02-16-2012, 12:56 AM   #1
Patriot
Question Any SRW 1 Ton 4x4 guys here?? Pictures??
I have two 1 Ton 4x4 SRW trucks and was wondering if there are any 1 Ton guys here?? I don't mean dually 1 Tons but the Single Rear Wheel kind?? I want to put the drive train under one of my K5 blazers to make an awesome bugout rig. I was wondering if Russ could respond because I was sure he did this???
Thanks guys and please send pictures if you have them. My trucks are in process right now with thre K5 Blazers also.
Patriot is offline   Reply With Quote
Old 02-16-2012, 01:17 AM   #2
rcbildr
rcbildr's Avatar
Re: Any SRW 1 Ton 4x4 guys here?? Pictures??
I've got an 83 2wd 1-ton. We use it to haul our camper. I'll get some pics tomorrow.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 02-16-2012, 01:53 AM   #3
joe231
joe231's Avatar
Check the link in my sig
My un-named CCLB is a 1991 SRW 1 ton with a 6.2 diesel and 4L80E trans...
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-16-2012, 06:58 AM   #4
GM72K10
Next!
GM72K10's Avatar
CUCVs count of course!
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 02-16-2012, 07:39 AM   #5
I never see Russ on here any more.I see he's on CK5 a good bit. I had an '84 K/30 20 or so years ago and sure would like to have another. I have a set of axles handy. I'd like to do what my good friend did with an '85 K1500 High Sierra he bought that was pretty clean. He rebuilt a Dana60 and 14-bolt,put a locker in and disc brakes on the rear,2' lift,285/75-16s on 7" Ford steelies,TH400/NP205,and winch. Now all he needs are 3500 emblems. The only thing I'll do different is I have the 4L80E from my '91 Suburban.
I have an '85 Jimmy I put 3/4t axles in and it was a cinch. 1t axles would be just as easy. It worked out that I didn't have to touch the rear driveshaft because of the larger 14-bolt. I used a conversion u-joint at the rear. This is temporary with the plan being to shorten the Suburban driveshaft.
Old 02-16-2012, 09:11 AM   #6
csa daddy
csa daddy's Avatar
Got a 91 sub I'm putting a ton front in to match my rear which has 4:56 gears with a locker an I'm putting a 6.2 diesel in it an have 8ooolbs winch for front or rear six inch lift an 35s swampers
csa daddy is offline   Reply With Quote
Old 02-16-2012, 10:17 AM   #7
Cheng
1985 K30 SRW owner here in Jacksoville, FL.
Cheng is offline   Reply With Quote
Old 02-16-2012, 12:31 PM   #8
324matt
324matt's Avatar
I have a 1987 V30 SRW 4x4. It has the T.B.I. 7.4L, TH400, NP205, 4.10 gears, and true dual 3" exhaust with flowmasters. Its up to 77,235 original miles. The paint is crappy as usual for those years, but there is no rust what so ever on the truck. The interior is a 7.75 out of 10. .
1985 GMC K2500. 350/TH400/208. 4:10's. stock.
1987 Chevy V30. 454/TH400/205 4:10's. Stock SOLD.
324matt is offline   Reply With Quote
Old 02-16-2012, 05:02 PM   #9
Patriot
When I was in the Army we still had those around and even a few new H1s. I still would rather have the Chevy trucks/Blazers than an H1.
I bleed Bowtie.
Old 02-16-2012, 05:27 PM   #10
324matt
324matt's Avatar
here are some pics.
Old 02-16-2012, 05:44 PM   #11
324matt
324matt's Avatar
more
Old 02-16-2012, 05:52 PM   #12
324matt
324matt's Avatar
interior
Old 02-16-2012, 06:02 PM   #13
324matt
324matt's Avatar
more
Old 02-16-2012, 06:06 PM   #14
324matt
324matt's Avatar
a few more
Old 02-16-2012, 08:38 PM   #15
Stew_Magoo
Here's mine...
Stew_Magoo is offline   Reply With Quote
Old 02-16-2012, 08:40 PM   #16
russgt
russgt's Avatar
I've been working on something similar, 1 ton running gear under a 76 blazer. Life has been getting in the way lately but I've been stocking up on parts.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 02-16-2012, 08:41 PM   #17
Stew_Magoo
And some pics of my shot ass interior...
Old 02-16-2012, 08:51 PM   #18
Patriot
Hey Russ, hows it going? I wanted you to comment because you have done the 1 Ton thing under a Blazer.
Old 02-16-2012, 09:00 PM   #19
Patriot
I have had a few Dyno/GT BMX bikes like that one. I miss mine.
Old 02-16-2012, 09:26 PM   #20
chevysmithz71
chevysmithz71's Avatar
Here is my latest one to pick up. I had the same idea on pulling axles like you and going under the K5. Did it a few years ago from a cucv and wheel it now.
chevysmithz71 is offline   Reply With Quote
Old 02-16-2012, 09:31 PM   #21
Patriot
Nice Blazer. My three Blazers are rust free and it makes me cringe to think about cutting up the body for bigger tires. I'll probably just stick to 35" tires on the 1 Ton axles. Wussy I guess.
Old 02-16-2012, 09:41 PM   #22
Evil Trailblazer SS
Big Gulps Huh? Whelp...
Evil Trailblazer SS's Avatar
Mine is a dually now but withing the next week or so it will finally be SRW!
Upholstery as it came to me with 52,300 original miles...
Upholstery now!
Carpet when delivered.
Interior fully stripped, cleaned and Dynamat Exteeme Installed!
Carpet and door sills now!
Headliner and sun visors restored...
Dash fully restored with ALL NOS PARTS!
Tach cluster restored and installed!
Now, WFO Concepts has the 14BFF right now do it can be gone through and an Auburn LS added and then we are good to go for the SRW swap. Then off for paint and body and then lift and tires/wheels!
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
Evil Trailblazer SS is offline   Reply With Quote
Old 02-16-2012, 09:53 PM   #23
Patriot
Upholstery now!
VERY NICE SIR!!!!!! I miss my Dually something aweful. EXCELLENT pull trucks.
Old 02-16-2012, 10:14 PM   #24
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Gentleman ,
This is not the classified section of the board . No more for sale stuff
powerdriver 1958 is offline   Reply With Quote
Old 02-16-2012, 10:32 PM   #25
yousesteers
here is mine
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
