Old 02-18-2012, 08:29 PM   #1
jlaird
jlaird's Avatar
My wheel idea for 20" steelies
Plan A is 15" steelies with stock dogdish caps. Here is plan B: I was thinking 20" steelies would look cool with dogdish caps, but no one makes them. I know about the dodge stockers, but welding the holes up in the center and the fact they are the wrong lugnut pattern lead me to another thought. Coker tire has 20" steel rims in 5x5, but the widest they make them is 6" wide. So my thought was to see if a wheel company can widen those. Alternatively, I was wondering if it would be easier to take the dodge wheel, remove the center, and put the Coker center in it, if of course it fit. Any thoughts? I'm crazy, good idea??
jlaird is offline   Reply With Quote
Old 02-18-2012, 10:03 PM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: My wheel idea for 20" steelies
I have considered this as well. I think it's do-able, but the biggest thing is the diameter (O.D.) of the Coker center in relation to the I.D. of the Dodge outer shell. If it's the same, you're good. If not, then that can be a huge issue.
I did a bunch of research and found a few companies that make wheel parts. The one with the best selection is Marsh Racing Wheels:
http://www.mrt-wheels.com/catpages/wheel%20parts.html
There are pros and cons to this. As far as the Pros, you can have a cool looking wheel that'll possibly accept a stock hubcap. The Cons are the cost, and the fact that a 20" steel wheel with any kind of width will be a heavy mutha.
Delmo went through this as well, and wound up buying 20" smoothies from Centerline and adapting a stock cap. In the long run, it'll be close to the same price, and it'll be a whole lot lighter.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 02-19-2012, 02:47 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by chevyrestoguy View Post
...Delmo went through this as well, and wound up buying 20" smoothies from Centerline and adapting a stock cap..
That the best option in my opinion
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-19-2012, 04:23 AM   #4
andrewmp6
How much are the centerline smoothies tho? Only other option i see is running good adapters for 6 lug then using the dodge or 09-2010 nissan titan or armada steel spares.
Old 02-19-2012, 06:15 AM   #5
jlaird
jlaird's Avatar
Centerline isn't an option for me. They don't have the "look" of a traditional steel wheel...to flat.
How much do the dodge wheels weigh?
Old 02-19-2012, 03:55 PM   #6
SCOTI
SCOTI's Avatar
Have you spoken w/a Coker rep yet?
I would verify what the actual 20" wheel looks like as well as what type of hub-cap they accept as the pic attached for their product view is the same pic pasted over & over regardless of wheel diameter.
Many larger diameter steel wheels have noticeable transitions from the wheel hoop to the center hub. Be sure you know what the actual appearance of the wheel you're looking into will be.
It also looks like those wheels would accept the car type caps that snap on agaist 'nubs' on the inside suface of the raised hub portion on the wheel vs the 6x-87 truck dog-dish caps which snap on agaist the outside of the raised hub portion.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-19-2012, 04:09 PM   #7
theastronaut
theastronaut's Avatar
The biggest problem with newer 18/20" OEM steel wheels is they have too much backspacing so they require thick spacers to get the wheels to fit in the fenderwell. They still don't look right with the wheel center so close to the outer lip. I've tried reversing the center on one of my 18x8" Titan wheels but then it didn't have enough backspacing- like only 2.25". The drop center isn't wide enough to adjust the wheel center closer to the center of the rim like factory 8" rally's with 4" backspacing. Theres more info on fitting titan steelies on pg 2-3 in my Goldilocks build thread.
Another option instead of filling in the slots to make a smoothie is to fit a moon disc over the wheel center, then add hubcap clips to hold the factory caps.
theastronaut is offline   Reply With Quote
Old 02-19-2012, 06:30 PM   #8
jlaird
jlaird's Avatar
Scoti, I wasn't planning on the stock dogdish fitting on the Coker wheel via nubs. That would be a bonus, but I was thinking I would need to put some type of clip on those to make the cap fit. I would definitely get a picture with specs from Coker before taking tha plunge.
Old 02-20-2012, 09:55 PM   #9
RAYDAY
RAYDAY's Avatar
any one call coker to see if they can get them wider?
96 s10 static drop smooth and blue
99 silverado nothing stock layed out on 24s
65 c10 bagged patina driver
http://www.myrideisme.com/Garage/az480
half-assed build thread
http://67-72chevytrucks.com/vboard/s...=1#post5206828
RAYDAY is offline   Reply With Quote
Old 02-21-2012, 12:12 AM   #10
jlaird
jlaird's Avatar
I called today and got some info, but not what I really wanted to know. I'm hoping to get a call or email back soon. I first called Coker and the guy says they don't make them, Specialty Wheel does. Well that was half true after a call to Specialty wheel. They make all sizes except the 20 inch. The 20 is made in-house at Honest Charlie's Speed Shop. So I'm waiting for a picture and some specs, but I'm not holding my breath.
Old 02-21-2012, 12:07 PM   #11
duceducenine
duceducenine's Avatar
a little off topic hope nobody minds...
what size tires will fit on a cokers 20x6?
will 235 45 20's work or would it
look odd? ballon out to much?
duceducenine is offline   Reply With Quote
Old 02-21-2012, 12:58 PM   #12
jlaird
jlaird's Avatar
go to tirerack.com, do a search for that tire size, and it will tell you under the spec tab the approved rim width range. For a 235/45/20, it says 7.5-9" for a Bridgestone.
Old 02-21-2012, 05:59 PM   #13
duceducenine
i've seen the specs before but they can be stretched...
i've had a 275 50 15 on 6.5 rim
they suggest 7.5-9.5 so thats what im wondering?
plus the 235 45 20 has a pretty tall sidewall...
Old 02-21-2012, 08:40 PM   #14
SCOTI
SCOTI's Avatar
i've had a 275 50 15 on 6.5 rim they suggest 7.5-9.5 so thats what im wondering?
Why?
235's are common on duallys which utilize 6.5" wheels so it would work. Wouldn't be ideal, but would work. IMO, a 6" wide 20" diameter wheel would look like an old wagon wheel on a model-t.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-21-2012, 11:10 PM   #15
502ms
502ms's Avatar
I really doubt a 275/50 will fit anything less than 8" wide, let alone 6.5".
I say this because a 275 is usually what I use for all of my cars that run a 10" wide wheel...methinks there is no way that will seal or mount up with all of that real estate on either side
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 02-22-2012, 05:01 AM   #16
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
I put the Dodge 20 steels on my truck. Went with a 1 1/4 adapter and they fit fine with a 255/35-20 tire. It was pretty close to rubbing the outer fender lip so I messaged it a bit.
MOTOIMPAIRED is offline   Reply With Quote
Old 02-22-2012, 01:51 PM   #17
duceducenine
the rear wheels are 6.5 and the tires are 275 50 15
didnt have and issues....
Old 02-26-2012, 01:00 AM   #18
rudy350
U have any more pics of your cool blue Chevy?? U can post.... What size your running on the front and rear, rim and tires?
rudy350 is offline   Reply With Quote
Old 03-02-2012, 11:10 AM   #19
cajundragger
the more sidewall you have the wider tire you can fit on a narrow wheel.
I have the dodge wheels. Added 1" of bs to the front and widened the rears to 10's with like ~3" of bs I think. Its not much.
they are heavy but I can't say I notice the weight. Its really not much more than a billet. Its will spin the tires in nearly any gear and stops just fine with 4 wheel disc.
cajundragger is offline   Reply With Quote
Old 03-02-2012, 11:21 AM   #20
aggie91
I'm just glad to be here!
aggie91's Avatar
Who did the backspace change and widening of your wheels?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-02-2012, 11:41 AM   #21
cajundragger
stockton wheel.
I've heard they went out of business. They were a pain to deal with. Told me 4-6 weeks to complete. It ended up taking a little over 3 months.
Old 03-02-2012, 07:18 PM   #22
way2lo2
way2lo2
way2lo2's Avatar
I've got 20" centerline smoothies on my later model crewcab and they weigh more the the dodge 20", they took quite a bit of weight to balance out on both sets of tires that I had on them. The look was cool but I think I'm going back to 15" or 17" Steelies with a fat tire since I mostly use the truck for towing anymore. I've ran them painted with dog dish caps for about 5 years and I think its time for a change
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Way2Lo2@aol.com <----also my paypal
http://www.hubgarage.com/mygarage/way2Lo2
way2lo2 is offline   Reply With Quote
Old 03-02-2012, 07:23 PM   #23
SCOTI
SCOTI's Avatar
I was curious about this very thing (If Centerlines forged wheels were lighter, would the Smoothies be lighter vs comparable sized wheels of different materials?).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-02-2012, 07:48 PM   #24
way2lo2
way2lo2
way2lo2's Avatar
I have one in the box, i'll weigh it this weekend
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 03-03-2012, 02:51 AM   #25
cajundragger
IIRC, My dodge wheel have maybe an ounce at most. I didn't even balance them for the longest time.
