Old 02-18-2012, 10:07 PM   #1
Sideways
Sideways's Avatar
Dual tanks switch plate?
I have a '72 Sierra Grande with dual tanks and the lever to switch them is mounted between the driver's rocker and the seat on the floor pan.
There is a plastic plate to indicate which position the lever is in, is this a factory item and is it available?
Many thanks!
Sideways is offline   Reply With Quote
Old 02-18-2012, 10:26 PM   #2
Achevytruck
Re: Dual tank switch plate
im looking for the steal plate that tells you what way to turn the handle on the switch
im looking at a truck online used to have the three tank set up
Achevytruck is offline   Reply With Quote
Old 02-19-2012, 12:17 AM   #3
oklalawnboy
oklalawnboy's Avatar
Mine was made of metal. Wish I didn't throw it away. I would have given it to you.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 02-19-2012, 12:02 PM   #4
Sideways
Sideways's Avatar
So what year would those be?
Old 02-19-2012, 12:40 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Not factory.... most were dealer-installed aftermarket. Travel Tanks was one of the more popular ones, at least on the west coast. That's what I have and it has a plastic indicator plate.
Mine has a 'pointer' on the handle, at the short end opposite from where you grasp it to turn. Pointed end towards the rear selects the main tank (behind the seat)... point to the right selects right tank and point to the left selects left tank.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 02-19-2012, 01:34 PM   #6
Sideways
Sideways's Avatar
That sounds like mine but it listed on the option list,it also has a switch on the dash to check to fuel in each tank.
Old 02-19-2012, 04:12 PM   #7
Achevytruck
Found this picture online befor and this one looks like the one thats in one of the trucks im looking at online i be getting [IMG][/IMG]
Old 02-19-2012, 04:28 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yours is obviously a factory option, and not what I was picturing by your description.
Besides the floor-mounted valve to select the tank, mine has a 3-way toggle switch under the dash for fuel gauge selection.
- Mike -
RIP El Jay
Old 02-19-2012, 04:36 PM   #9
Sideways
Sideways's Avatar
That looks like my switch but there is a plastic plate that is on the carpet that indicates which tank.
One of the seals in the lever went and the fuel wicked up the shaft and melted the plate.
Old 02-19-2012, 06:04 PM   #10
Psychdave80
I bought a replacement at a local oriellys auto parts store but I had tried 4 other stores before I found someone that understood what I was looking for they called it some kind of valve but it didn't have any indicator plate with it, and my truck just has the 2 tanks so if you flipped it the wrong way if would just cut the fuel off
Psychdave80 is offline   Reply With Quote
Old 02-19-2012, 07:08 PM   #11
MusicMan70
MusicMan70's Avatar
My 70 has this sticker, but I believe you refer to the third photo...not sure where to obtain it. Boat supply business maybe?
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 02-19-2012, 07:30 PM   #12
Sideways
Sideways's Avatar
That's the one, third pic!
Any other leads will help, Thanks.
Old 02-19-2012, 07:38 PM   #13
Achevytruck
MusicMan70 i do not want the last one if the pictures you post it. im wanting to find the one that flat and thick as a dime or less , maybe should ask that guy name randy
Old 02-19-2012, 07:52 PM   #14
Sillyoldman
#16876
Sillyoldman's Avatar
Couple more for you.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 02-19-2012, 08:20 PM   #15
Sideways
Sideways's Avatar
Thanks, hopefully someone has a source so I can pick-up a replacement.
Old 02-19-2012, 09:20 PM   #16
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Dual tanks switch plate?
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 02-19-2012, 09:32 PM   #17
Nut4Trucks
My 72 GMC K2500 has the exact same plate and mine has a factory auxilary tank with a filler neck in the beside right in-line with the cab tank style line. I have never seen them available in the aftermarke. I would assume the only option would be to restore it as best you can.
1972 GMC K2500
2006 GMC K2500 Duramax
Clarksville, TN
Nut4Trucks is offline   Reply With Quote
Old 02-19-2012, 09:35 PM   #18
davepl
davepl's Avatar
Look for branding. I can't say there -wasn't- a factory option, but all the ones that I've ever seen, including mine, were dealer options.
So far as I know the factory option was for a single aux tank, but others will chime in...
davepl is offline   Reply With Quote
Old 02-19-2012, 09:50 PM   #19
Sideways
Sideways's Avatar
Not an option , it is dissolved!
I might make one out of brass,engrave the faunt and have it chrome plated...or maybe do one in stainless.
Old 02-19-2012, 09:53 PM   #20
Achevytruck
hopeful i can and who ever eles able to find a plate
Old 02-19-2012, 11:05 PM   #21
into69z
"brand new second-hand"
into69z's Avatar
sideways-Why not contact board member Teeitup or others who post parts for sale. Teeitup is always parting trucks as well as others and I'm sure they come across these pieces all the time. Good luck.
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
