Old 02-19-2012, 12:56 PM   #1
417 Motorsports
Frame mounted brake booster vs exhaust clearance
Anyone have some good under vehicle pics or cab off pics of exhaust clearance with a frame mounted brake booster (1950) and motor and auto Trans mounted??
Wanting to go this route but before I order the parts I want to make sure I don't have to run the exhaust low or routed in a awkward manner. Or is this normally even an issue?
Blake
417 Motorsports is offline   Reply With Quote
Old 02-19-2012, 09:57 PM   #2
papastrk
Re: Frame mounted brake booster vs exhaust clearance
It was an issue on my 59 truck. I have a 3" exhaust and turbo 400 with a two stage booster. Things got close on the drivers side, but I would still recommend the frame mount booster. Just keep in mind that you must clear speedometer cable, booster and shift lever when fabricating exhaust. And I ran the exhaust over the trans crossmember. I did notch crossmember as it was 2" square tubing. No pics. Sorry.
papastrk is offline   Reply With Quote
Old 02-19-2012, 11:22 PM   #3
nebdrummer
nebdrummer's Avatar
This solves the issue.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 02-20-2012, 01:35 AM   #4
_Ogre
_Ogre's Avatar
i have 1000's of pics of my truck, none of the exhaust or under the truck after assembly.
the lowest thing on a 47 to 59 truck is the bottom of the doors and steps, on my 58 the door is 5-6'' lower than the frame.
it makes it a pain in the butt to get on a hoist, but easy to run an exhaust to the rear axle.
my exhaust is 3-4'' below my frame, every frame mounted booster is frame mounted
i can't imagine any clearance issue with an exhaust system.
i can't imagine any need for a 3'' exhaust system either.
shop air compressor timer
Old 02-20-2012, 09:57 AM   #5
papastrk
[i can't imagine any need for a 3'' exhaust system either.QUOTE][/QUOTE] LOL, 3" exhaust as in "Corvette"
Hey Blake. Do you make the street rod show there in Springfield held in May? That show is one of our favorites.
Old 02-20-2012, 05:22 PM   #6
OrrieG
OrrieG's Avatar
Here is what I have for photos from the engine to the mufflers. I used stock rams horn exhaust, under frame brake booster and MC, auto trans and transfer case, keeping the original crossmember and modified stock trans/transfer crossmember. The original muffler guy did a good job of keeping everything up high so there was less to scrape off with rocks and logs. It is 4wd so I had a little more room to work with, but good muffler guys can do amazing work.
Old 02-21-2012, 10:32 AM   #7
usmc_butler
usmc_butler's Avatar
Here was my fix, I sure hated to do it this way but better then the exhaust heating up my wiring harness and booster... But it works and have no worries now
"I'm as confused as a baby in a topless bar"
57 Fleetside Build Thread
usmc_butler is offline   Reply With Quote
Old 02-22-2012, 12:14 AM   #8
parkwood
parkwood's Avatar
1952 suburban
parkwood is offline   Reply With Quote
Old 02-22-2012, 02:49 AM   #9
rsb5772
rsb5772's Avatar
I don't know what you think about them, but Sanderson headers that route through the inner fenders would fix the problem.
rsb5772 is offline   Reply With Quote
