Old 02-20-2012, 01:19 PM   #1
Car'n'Guitars
Car'n'Guitars's Avatar
Question Distributor
Were HEI Distributors the only type of distributors used on the 85 trucks? Or were they uncommon and not stock?
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 02-20-2012, 01:27 PM   #2
irishman999
irishman999's Avatar
Re: Distributor
As far as I know thats the standard.... Its what my 85 has HEI too.
irishman999 is offline   Reply With Quote
Old 02-20-2012, 01:32 PM   #3
mooseknuckles
mooseknuckles's Avatar
Re: Distributor
HEI been the standard for quite some time....since the early seventies
mooseknuckles is offline   Reply With Quote
Old 02-20-2012, 01:43 PM   #4
Car'n'Guitars
Re: Distributor
Okay thanks, what are some common problems with these?
Old 02-20-2012, 01:48 PM   #5
Indyuke
Re: Distributor
The only problems I've had in the past with HEI systems are:
- HEI module overheating and burning out
- coil going bad
- dist cap cracking
- mechanical advance freezing up
- poor timing curve (designed that way for emissions reasons)
Other than that, I've had less problems with them than the conventional points style. At least less maintenance is involved.
Indyuke is offline   Reply With Quote
Old 02-20-2012, 01:51 PM   #6
Car'n'Guitars
Re: Distributor
Is there a special way to work on these and go through them? For example with maintenance if the truck has been sitting for some time?
Old 02-20-2012, 02:58 PM   #7
irishman999
Re: Distributor
As far as maintenance I would just replace the cap and rotor. There is a ground strap that screws into the metal part of the coil that is very easy to loose. If you put it back together without it the truck will start and sometimes it wont, I battled this for a while before I figured it out. You could also check out the mechanical weights, take them apart and grease them if there is surface rust.
Old 02-20-2012, 03:28 PM   #8
Car'n'Guitars
Re: Distributor
Okay does anyone have a diagram or pictures of these apart? The last time this truck ran it ran like sh*t. And then after that it just wouldn't even start, so I replaced the spark plugs, fuel filter, fuel pump, and the fuel line from the fuel pump to the carburetor. So I want to check out the distributor before I try to start it and get it running again. So that's why I'm asking all these questions.
Old 02-20-2012, 03:40 PM   #9
Stepper86
Stepper86's Avatar
Re: Distributor
Take off the cap and clean it, and the rotor. Make sure you get all the green oxidation off the contact points in the lid and on the tip of the rotor if there is any (spraying it with brake clean works good)
Re-assemble and test for spark ( hook up a loose sparkplug to one of the cables and ground it. Ask someone to crank the engine while you watch for a spark. If you get one you are good to go for now. If you get fuel to the carb your truck should fire up.
It might run rough after standing so long, but if there is life there is hope. If it runs itīs easier to truble shoot and find the reason why itīs running rough, vaccume leaks etc
Tom.______________________________________
The fleet:
2007 BMW 530xi M (daily driver)
1986 C-10 Stepside (project "my time")
1992 Corvette cab (summer time daily driver)
1969 Cadilac DeVille Cab ("it just need some paint")
Stepper86 is offline   Reply With Quote
Old 02-20-2012, 03:52 PM   #10
Car'n'Guitars
Re: Distributor
Yeah the truck ran then winter hit and it wouldn't even start. Do you have any pictures of a distributor apart?
Old 02-20-2012, 04:24 PM   #11
Pop's C-10
Pop's C-10's Avatar
Re: Distributor
Here you go..it's good for all years..it says 75-85 cause it from a corvette site
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 02-20-2012, 04:30 PM   #12
Stepper86
Stepper86's Avatar
Re: Distributor
Sorry no pictures of it open, maybe someone else here have some.
The fleet:
Old 02-20-2012, 04:32 PM   #13
Car'n'Guitars
Re: Distributor
Okay thanks this helps me. I'll look in to it in a little while.
Your covered thanks anyway.
Old 02-20-2012, 04:42 PM   #14
Car'n'Guitars
Re: Distributor
Is this the right firing order for my truck? It's a 85.
Old 02-20-2012, 04:47 PM   #15
78 Chevyrado
Re: Distributor
Thats correct.
78 Chevyrado is offline   Reply With Quote
Old 02-20-2012, 04:53 PM   #16
Car'n'Guitars
Re: Distributor
Okay thanks.
Old 02-21-2012, 09:07 PM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Distributor
check the vac advance
found mine sticky 78
dosn't leak but will suddenly move
weights were moist and rusty before
i cleaned them, also spotted the rod was rusted at a small spot in the hole (you can barely see the mark after cleaning that)
also the cap i bought a "tip" pulled out,some are press fit it seems
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-21-2012, 09:25 PM   #18
Car'n'Guitars
Re: Distributor
Thanks motornut that helps me in what I need to look for.
Old 02-21-2012, 10:56 PM   #19
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Distributor
if you suck and release on the vac advance, it should move freely, while looking at it
make sure the weights move/swing out ok too
John
Old 02-21-2012, 11:09 PM   #20
Car'n'Guitars
Re: Distributor
Alright I'll try to check all this out tomorrow, but first comes my fuel line work. Thanks for all the info.
Old 02-22-2012, 01:03 AM   #21
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Distributor
some times you can bend lines around soup cans etc
just don't try a table edge,or a corner ....it will get kinky on ya lol
John
Old 02-22-2012, 07:05 AM   #22
Car'n'Guitars
Re: Distributor
Yeah I have been using all round objects.
