02-20-2012, 09:39 PM | #151 |
Re: 1948 Chevy / S10
Dude! im tired just reading this
1950 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=335667 1965 F*rd Stang http://67-72chevytrucks.com/vboard/s...d.php?t=399891 1931 F*rd Model A http://67-72chevytrucks.com/vboard/s...d.php?t=496016 1954 Chevrolet Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=486183 |
02-20-2012, 10:21 PM | #152 |
if it isn't one thing it is ten others. I feel you on that. the doors look great, I like the attention to detail you use. however, when you use the weather strip, how are you going to keep it all nice and flush like you have it? When I put weather striping in, it really made the doors fit like crap, so I gotta get on fixing all that.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
02-21-2012, 08:48 AM | #153 |
Great job on the gaps xpickup!
We all like a good gap over here too! Regards, Trently. Posted via Mobile Device |
02-21-2012, 08:51 AM | #154 |
mine look good after a 12 pack,good job keep on going.
02-21-2012, 10:49 AM | #155 |
Shannon, seem like life has a way with messing with us, but as usual you took care of the problem. Nice job on the doors.....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
02-21-2012, 06:48 PM | #156 |
britnjc, It is never a dull moment at my house.
99 to Life, I know what you mean, Yes, I thought of the weatherstripping deal. If the factory is to thick then he will just run some of the aftermarket self stick stuff. At least the gap are even. AUSSIE54, Thank you. Did you cut that center pillar out yet. HAHA Larry Lindley, Thank you. Just think how great they would look after a 24 pack. oldman3. Thank you. I have had a bad last 6 months with water. Roof, flooded basement, and now the bathroom plumbing. My 80 year old house should be good as new for a while! Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
02-23-2012, 10:59 PM | #157 |
On to the passenger door now. I have the back of the door gap fixed and started on the front now. I should have the door finished after work tomorrow. Then I have to finish the 55 brow on the underside on the passenger side and make the tabs that the screws on the headlight bezel mount to on both sides at the top. Then finish welding the fire wall. Then straighten the hood and remove the center seam. I am also putting in a 55 chevy gauge bezel, so I have to modify the dash for that. Then this weekend I am going to cut out the corner windows on a bad cab and turn another buddies good cab into a five window in the near future. I am addicted to these trucks!
Shannon
02-24-2012, 12:17 AM | #158 |
Shannon, door looks great, looking forward to seeing the hood work and how you handle it.....Jim
02-24-2012, 09:51 AM | #159 |
oldman3, Thank you. This time I am going the cut the whole step formed center out and put a 1.5" piece in. I will do it in pieces that way the hood does not loose its shape. Then I can hammer and dolly it back to shape. The last one I only welded in 5/8" strip in so it was double thickness and it still had the 90 degree bend on it. I had to grind the 90 degree bend off and then it was still hard to hammer and dolly. That might be the project for the week end.
Shannon
02-24-2012, 07:16 PM | #160 |
Shannon,
Got the template in the mail today. Thank you! Atommik
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
02-24-2012, 08:25 PM | #161 |
Certified Car Nut
Great work as always Shannon.
02-24-2012, 10:10 PM | #162 |
Atommik, no problem.
Kabwe, Thank you. Have not seen you on for a little while. Since you are a 55 guy I wondered what you thought of the eye brows on the fenders? Have you done much on your truck? Shannon
02-24-2012, 10:17 PM | #163 |
Certified Car Nut
I think all your metal work looks great I really like looking at your build. As far as the truck yes I've been working on it but nothing to write home about.lol
02-29-2012, 10:50 PM | #164 |
Hey Shannon, just wondering how things were going with the hood, any updates, love looking at your work.....Jim
03-02-2012, 08:11 AM | #165 |
oldman3, I have the hood mostly done. It will be finished on Sunday. I have not been on to much due to us being swamped at work. The center was all cut out and the new was put in. It warped out a little so I had some work straightening it out. I have to take out the inner front panel because I can clean back behind it and the drivers corner was hit alittle, so it needs some work. I am stripping all the paint off of it so I can fix some small dents. Then I will be moving onto the next couple things I have to do yet and then send it home. And soon back onto the panel.
Shannon
03-02-2012, 11:57 AM | #166 |
Sounds like you been busy, at work and at home....Jim
03-04-2012, 08:51 PM | #167 |
Well, today was a 10 hour day. I got a lot done. Started out fixing the drivers door. Once I shaved the drip rails off I noticed that the top of the door sat in farther than the passengers door. I noticed it on my panel truck too and I checked my 54 cab that I have and it was like that too. So I slit the back side and pulled it out where I wanted it and put a screw driver it the slit to keep it there so I could tack it. Then welded it up and now it fits right. Then I had to finish the gaps on the doors, and now they are done. Then I welded the fire wall in, I only had it tacked in before. Then finished the underside of the passenger headlight brow and they are now finished. Next was the hood. The center is all done and smoothed out and I cut out the front emblem holes and made panel for them. I drilled out the clutch head bolts under the hood to fix the corner of the hood. I figured I would never get them out. After I drilled them out I welded nuts to the underside of the panel so it bolts up like it did. I still have to fix the front edge because it is dented up. I found some filler in the hood so I will hammer and dolly it so it will not need to much. Here are some pictures.
Shannon
03-04-2012, 08:54 PM | #168 |
some more
Shannon
03-04-2012, 10:00 PM | #169 |
Looking great Shannon! What are you using to make your fillers, 18 gauge 1018 sheetmetal? Since you're planishing the hood pieces, are you MIG or TIG welding it in?
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
03-04-2012, 10:12 PM | #170 |
great job !
03-04-2012, 10:19 PM | #171 |
Shannon, excellent work as always, everything looks great.....Jim
03-05-2012, 12:01 AM | #172 |
Sweet job on the metal. That is a unigue firewall. I assume you made it yourself. You could probably market that design.
av8tr33337 AKA Bartman Email av8tr33337@yahoo.com Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
03-05-2012, 09:24 PM | #173 |
Wow, over 500 posts. I just saw that!
BlueJeep, Thank you. Yes, I am using 1018 sheet metal. I am using MIG. I have a TIG but need to get some smaller tungsten for doing sheet metal. Just have not had time to mess with the TIG on sheet metal too. I would have loved to go to one of those sheet metal workshops you went to. I love doing sheet metal. Daze57, Thank you. oldman3, Thank you. It would have been a lot easier to just fill that step in the hood! At least the filler would have not warped the hood! I got most of it out just a little work on it yet, like the front edge. av8tr33337,Thank you. I must confess it was not my idea. Ironworks and Nsane were the ones that I saw do it, I just made the one for this truck. Shannon
03-05-2012, 10:46 PM | #174 | |
Keep up the great work!
03-08-2012, 09:52 PM | #175 |
BlueJeep, I would like to try that steel but like you said it is hard to find. I would like to see the difference working it. I will have to try that tungsten. Was he using a inverter machine or a transformer machine? I was told to use a smaller tungsten like 1/16 for sheet metal. I too do not like to spend all to time when I know I can do it quick with MIG. But I know it works better than the MIG when metal working something that was TIG welded.
Shannon
