Old 02-21-2012, 12:38 AM   #1
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Custom sealed up bed- Drain?
my 61 will have a custom inner bed, I had panels bent out of sheet steel, and will weld it all up....
I have seen lots of beds like this in street trucks/truckin/minitruckin, but, how do they drain? I don't want to turn it into a fish tank!, and I don't really want a visible hole in a random spot.....
just looking for ideas on what others have done....
Old 02-21-2012, 01:09 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Custom sealed up bed- Drain?
During the years I ran without a bed cover, the front of the bed filled up with water because the truck sits on a rake. I got tired of it and drilled a 1/2” hole at the very front end of each side angle strip. Even after washing the truck and hosing out the bed it would drain empty in a few seconds.
This approach might work if an inconspicuous cover of some type was fabricated with a concealed gap to allow water to vent without announcing its presence to the casual observer. Perhaps something like a miniature version of a vintage hood scoop with the opening facing the front of the bed.
Old 02-21-2012, 02:00 AM   #3
78 Chevyrado
only thing I can think of other than drilling a hole is to leave a pair of matching gaps where the metal joins up towards the front. It would look like a slot at the joint.
78 Chevyrado is offline   Reply With Quote
Old 02-21-2012, 02:49 AM   #4
MisterC
MisterC's Avatar
Markb hit the nail on the head. Many modern trucks have similar holes in the front corners. Most of the time, they're dimpled in somewhat, which makes it clear what they're there for, but also makes the surprisingly inconspicuous.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 02-21-2012, 03:20 AM   #5
jonzcustomshop
1961 crewcab
I guess that might be what I do, in essence I will have 2 beds to drain, the gate is welded shut, and with the notch I am going to have a front bed , and rear bed .
I have thought of getting some 60-66 bed strips and installing them over the steel floor (right now it is just 3/8 thick bare steel), maybe I can incorporate a drain under them.
