Old 02-21-2012, 11:34 AM   #1
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
3rd brake light working but no others
2007 1/2 ton Chevy pickup.The third brake light works and neither of the corner brake lights will work. My guess is the brake light switch is working or I would not have a 3rd brake light. All turn signals, 4 way flashers and tail lights are working. Any and all help appreciated...Roger
CaptRMW is offline   Reply With Quote
Old 02-21-2012, 01:33 PM   #2
Boog
laying low
Boog's Avatar
Re: 3rd brake light working but no others
It's been my experience that the fuse in the power control center under the hood has a blown fuse. I had the same symptoms with my 97 GMC.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-21-2012, 02:11 PM   #3
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
I visually checked the fuses and they looked good, I may be wrong but would expect the fuse for the third brake light to be the same as for the corners. Thanks, Roger
Old 02-21-2012, 04:56 PM   #4
truckdude239
truckdude239's Avatar
bad bulbs
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-21-2012, 08:12 PM   #5
Boog
laying low
Boog's Avatar
Actually they are not on the same fuse. There is a fuse in the cab and a fuse in the power control center under the hood. The 2nd one I think is a 30 amp and powers the corner brake lamps. Do check to see if there is power going to the rear lights and inspect the bulbs. It is doubtful that both sides are blown at the same time though.
Make sure the trailer wiring harness at the bumper isn't damaged, maybe a pinched wire or damaged socket.
Boog
primer is finer
Old 02-21-2012, 08:25 PM   #6
truckdude239
hey i've seen it before just saying they both are on the same amount of time
David fuller
2000 Tahoe 5.3l 378
Old 02-21-2012, 09:33 PM   #7
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Visually checked both fuses today but will test them tomorrow as well as checking for power to the fuses. I will report my findings. Thanks, Roger
Old 02-22-2012, 07:06 PM   #8
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Both bulbs good just not making contact, what a POS system, glad I drive a 1970 with those horrible old 1157 bulbs that are bright as ever after 200,000 miles.
Old 02-22-2012, 10:04 PM   #9
Boog
laying low
Boog's Avatar
That'll do it. Thanks for the update.
Boog
primer is finer
