Old 02-22-2012, 02:29 AM   #1
Devillusion
Devillusion's Avatar
Some questions about CCSB conversion (in progress)
Already well into my project (see Project: Crew'd Attitude)
Have some questions though...
What did everyone do about the ebrake cable length? suburban rear cables? or?
Has anyone put 1/2 ton coils in the front of a 1 ton? What drop did you get with stock springs? or did you use drop coils? Measurements from rocker would be cool if possible....
Any direction would be appreciated, searched but came up with nothing.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 02-22-2012, 08:45 AM   #2
rs72z
rs72z's Avatar
Re: Some questions about CCSB conversion (in progress)
Posted in your build thread. I think the 1/2 ton springs are shorter than the 1 ton springs that would require moving the hangers, i think.
I havent done anything on the ebrake cable yet.
I used 2" springs and 3" spindles in the front and a flip in the rear. Thinking about some bags for the rear for towing.
rs72z is offline   Reply With Quote
Old 02-22-2012, 09:44 PM   #3
Devillusion
Was speaking of the fronts actually....sorry, should have been more clear.
So you kep the 1 ton springs in the front then? What did you do with the blue/silver reg cab?
Any chance you have measurements to compare?
Thanks!
1970 Chevelle
Old 02-22-2012, 09:52 PM   #4
rs72z
rs72z's Avatar
On the dually i used 2" dropped springs and 3" spindles.
The 87 1/2 ton i cut 1 coil from the stock springs.
I will go check the measurements.
Old 02-22-2012, 10:02 PM   #5
rs72z
rs72z's Avatar
Ok. 1 ton is 9" from rocker to ground with 235-75-16.
the 1/2 ton is 10" with 255-50-17.
I think i have something backwards 1 ton is lower than 1/2 ton?
Not for long though, after the dually is done the 1/2 is getting a little attention.
Old 02-22-2012, 11:59 PM   #6
SCOTI
SCOTI's Avatar
Specifics might be extra help here. Where was your dimension pulled from? Rocker area @ the front, middle, or rear of the cab?
1/2 ton springs could be used in place of the 1-ton stuff but how much drop to expect will depend on what drivetrain you have & what springs you use (new or 'aged').
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-23-2012, 02:10 AM   #7
Devillusion
hmmmm, well mine with bell tech spindles, and 1/2 a ring cut off the tons I sit 12" to the ground with 235/85/16s
What the hell?
1970 Chevelle
Old 02-23-2012, 08:28 AM   #8
rs72z
rs72z's Avatar
Front of thre rocker to the pinch right behind the fender. The drop springs i used were for a 1/2 ton also. Those 285"s are pretty tall also.
Old 02-23-2012, 09:14 AM   #9
SCOTI
SCOTI's Avatar
rs72z's 235-75's = 29.87"
Devillusion's 235-85's = 31.72"
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
