Old 02-15-2012, 06:03 PM   #1
Blazin77
Blazin77's Avatar
Help Stripped bolt...!!!???
I was going to take the top off of my 77 Blazer, first time its ever been off but the first bolt I tried to remove appears to be stripped it just spins and spins....
Anyone else have this happen ?? What is the best way to handle it ??
Thanks for the help
In the words of Huey Lewis.. "It's Hip to be Square".
1977 Blazer
............________
.........../_____ |__\__
..........|_(O)______(O)]
Blazin77 is offline   Reply With Quote
Old 02-16-2012, 12:31 AM   #2
UPNADM
UPNADM's Avatar
Re: Help Stripped bolt...!!!???
Drill the head off if you can.
UPNADM is offline   Reply With Quote
Old 02-16-2012, 01:18 AM   #3
rcbildr
rcbildr's Avatar
x2 Drill or grind the head off. The drill might just grab it and spin.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 02-16-2012, 02:36 AM   #4
texastruckjunky
texastruckjunky's Avatar
If you take off your side pannel (if it has one). There is a rectangular nut under the edge. you can put a pair of vice grips on the nut, and turn the bolt with a socket or wrench. Thats if it is not one of the bolts on the roof.
Life is to short to drive anything else
texastruckjunky is offline   Reply With Quote
Old 02-17-2012, 09:02 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
yup i have one that the "nut" came out of the holder under the lip
i have no panel so it's ez to grab
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-17-2012, 03:14 PM   #6
Blazin77
Blazin77's Avatar
Thanks for the replies I will give it a try this weekend if I don't get washed away, weather report's not looking good for the weekend...
Dusty
1977 Blazer
Old 02-19-2012, 10:01 PM   #7
Blazin77
Blazin77's Avatar
Thanks !! Took the side panel off, clamped on the rectangular nut with vice grips as directed and the bolt came right out no problemo..
Dusty
1977 Blazer
Old 02-20-2012, 12:25 AM   #8
texastruckjunky
Glad I could help.
Old 02-20-2012, 02:48 AM   #9
tobiahr
tobiahr's Avatar
now resist the urge to spot weld the nut on the body. they are caged loosely for a reason.
tobiahr is offline   Reply With Quote
Old 02-22-2012, 08:40 AM   #10
BigBlocksRule
Vise grips? Vise grips?
Took me a while to figure out what you're talking about.
That's an Oklahoma Socket Set, son. Learn the names of your tools!
Another one that's often mis-labelled is what some folks call a "torch". That's a "blue-tipped crescent wrench".
Glad to hear you got the bolt out without too much trouble.
BigBlocksRule is offline   Reply With Quote
