#51 |
Re: GMC paul door seals are great!
subscribed
'69 Fleet![]() It ain't yours, if you didn't build it! |
#52 |
Received mine yesterday....FAST shipping and these things are AMAZING!!!!
I am really sorry I waited so long to get these seals! They are easy to install and they seal great! Thanks GMC Paul...you are the man!!!!
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
#53 |
Looks great. I know it hasn't been very long since most had installed, just curious if any have actually been in the rain since. Paul, if I were to purchase the 71' cab kit, could you tell me what is not included? Thanks
project: "my happy mess" |
#54 |
I finished the interior in my truck today ,glued in new seals and the doors are hard as hell to close sooooooo i just ordered a set and the new glue in ones will hit the trash as soon as the push on set gets here ...
1972 Custom 10 LWB 1973 V8 Vega wagon 1925 Model T Wrecker 1913 Model T Speedster http://s181.photobucket.com/albums/x...07/72skoolbus/ |
#55 |
anyone?
#56 |
Just ordered a set this morning...can't wait to install them! Thanks GMC Paul
Recieved my door seals and installed them, they went on great, the only problem that I would like to mention is on a tight corner while pushing them on to fit tight the metal popped through the rubber, small area but still exposed the internal metal. Other than that they are great. Mines a weekly driver, so all is good.
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel Last edited by aventur1; 02-14-2012 at 11:10 AM. |
#57 | |
![]() Join Date: Mar 2000
robbinspd1199@yahoo.com litew8 If you read the description of the cab rubber kit on our web site page it tells you every part that is included in the kit. If you do not see it in the description then its not included. the following is that list Includes standard 8 piece door window seal kit, vent window rubber kit, door opening weather strip kit, windshield gasket ( Deluxe or Standard), Rear window gasket ( Deluxe or Standard) Specify Standard or Deluxe in Cart for 67-72 Large back window, 67 Small back window kit comes as standard or deluxe windshield gasket and standard rear window gasket specify in cart. You can optionally upgrade the door opening weatherstrip in the cart from our original style glue on version to our new and improved modern style that pushes on and requires no glue to install. Every Piece in this entire kit is backed with a lifetime warranty. You'll find the cab rubber kit at this link http://www.gmcpauls.com/Pickup.htm Its the 1st item listed on that page. Where as if you only want the Push-On door seals they are on the same page and are the 9th item listed on that page. GMCPaul |
#58 |
Thank you for the reply. I no longer need the door seals, so a kit isn't going to work.
I have a "Custom Deluxe", here's what I'm looking at now: 8 Piece Door Window Seal Kit For Custom & CST Trucks 280037 Includes inner felts with Chrome Bead, outer rubber seal, Division Bar Felt,&Door Glass Channel Run For Both Doors Used On CST & Custom Pickup, Suburban & Panel. LIFETIME WARRANTY. $69.95 67-72 Division Bar Felt 360342 1967-72 Door division bar felt runs down back side of vent window bar from top at door upper frame to bottom inside door. For truck, Blazer, Jimmy, Suburban, Panel. $12.00 67-72 Glass Run Channel 360346 1967-72 Door glass run channel, extends from inside door bottom at back of window up the rear glass run area and across top of door upper frame and ends at division bar. For Truck, Suburban & Panel. $10.95 - Questions - 1) Are all rubber products manufactured by Precision? 2) For the 8 piece above (280037), it says "outer rubber seal", but the 4 piece anti-rattle kit (371090) says "2-outer rubber seals with chrome top bead" is included. Is there a difference for Custom Deluxe models, and why wouldn't the 8 piece kit contain outer rubber seals with "chrome top bead"? 4 Piece Custom & CST Door Window Anti-Rattle Kit 371090 For 1967-72 Truck, Blazer, Jimmy, Suburban&Panel. Includes 2-inner felts with chrome top bead, 2-outer rubber seals with chrome top bead, at bottom of window inside and out, does both doors. LIFETIME WARRANTY. $39.95 Thanks
#59 | |
The part # 280037 includes 2 division bar felts and 2 glass run channels so if you only have the 1 truck there is no need to add the part #'s 360342 division bar felt or Part# 360346 glass run channel. we use a Part # 371090 + 2- Part # 360342 & 2 part # 360343 to make our Part # 280037 kit. To be sure your questions get answered quickly about any of our products you can contact us direct by emailing us at robbinspd1199@yahoo.com as I don't always see every post here. Thanks for your interest!! Paul @ GMCPauls |
#60 |
I bought these kits, liked all of it and fit was good. The only thing I did was cut my outside window seal to short, I did not consider going past the wing division bar another 1/4 inch to seal that little area.
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
#61 | |
Thank you for taking the time out of your busy schedule to answer a few questions! Really appreciate it! I know about the felt being trapped beneath the chrome on the division bar! I just finished sandblasting mine and noticed how some got trapped in that seam. The blaster cleaned it up good for me. Once I get organized, I'm going to buy from GMC Paul! Thanks again!
#62 |
![]() Join Date: Apr 2007
Got mine today--won't install for while but Paul my question is in the sharp corner of upper front --is there a trick to install in that area-no prebend in these so I was just curious---Shipping was super fast and where were these on my last 20 trucks???? lol.....thanx again.......jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
#63 |
jtp67-72
I would say just go slow and make sure it's tight push hard down to set as you go around that part keep the loose end pushing towards the part your pressing in the slot. The edges will seem so curl up as you go around corner so I used a very small screw driver to pull the lip up over the edge. Kinda hard to explain and the small loop wire inside the edgeing will tend to poke through, I just used the scew driver to lift edge and the wire will go back into the seal. You can use maybe stiff plastic so not to damage paint. It will be a little kinked at the 45 degree but as you shut the door it smooths out. When you get to the end I cut it a little long then cut the bottom and used the extra rubber on top to tuck into where you began.
#64 |
Thanx--figured someone had it figured out!.......jim
#65 |
My doors are hard to shut but are getting better every time, been in about a month.
#66 |
![]() Join Date: Sep 2011
I'd love to get a set of the "push-in" style for my '66 if you get those test fit and are happy with them.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
#67 | |
GMCPaul |
#68 |
Hey GMCPaul. Any progress on the "push on" style door seals for the 60-66?
#69 | |
Sorry I didn't have positive news for you. GMCPaul |
#70 |
No apology necessary. I appreciate the detailed response. Based on the praise they've received from other members, I may just try them on my 66 none the less.
Thank you very much!
#71 |
Just put another set on my K20....great product!
#72 | |
If so - My 62 C10 will have to have a set for sure. Thanks bob |
#73 |
![]() Join Date: Jan 2011
70 GMC here, push on type door seals. In 15yrs of restoring trucks and cars, these are top notch fellas. .. buy em. I'm confident to say they're if not the best out there, they're really close. (top two) They will be going on my 68 too.
#74 |
^^^^amen.......jim
#75 |
![]() Join Date: Apr 2012
I'll be placing an order for my 67 real soon.. Paul could you do the \/ cut prior to shipping them out ?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
