Aluminum body mount bushings on a C/10
I have heard of people using an aluminum bushing but I cant find any anywhere. Are people using Camaro, or Nova ,Chevelle body mount bushings ?? What has to be changed if anything?
The Older Generation
Re: Aluminum body mount bushings on a C/10
I never heard of such a thing but it depends on your definition of "body mount bushings". Body mount bushings are either rubber or poly and are designed to absorb vibration and road shock. Some people refer to the metal sleeves/spacers that go inside the rubber or poly bushings as bushings but I don't think that is correct. A picture of what you are referring to or replacing would be helpful. LockDoc
ultra performance cars have them but not really suitable for a street driven vehicle// as it is the poly bushings are plenty rigid and transfer enough vibration and noise to the cab that i've seen a bunch of guys dump the poly andd go back to the original rubber in a short period of time
Offroad designs, ord, sells 1" body pucks if you are so inclined...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
Collector of Projects
I have a set on my K5... They are spacers, not bushings. Bushings are two pieces that are stepped to fit together...
Ummmm, what I was asking about was a ''Body mount bushing" . Global west calls them bushings so I guess I will also. I was looking for aluminum for a reason, not for a vibration free ride. There are several people that have them but not for a truck, that is why I asked about a crossover part. Thanks
typically they are used on race cars for better transfer of weight etc. If you are wanting to use them i would take my old bushings and have a machine shop create them for you. As stated earlier it will be super rigid, but if you are looking to transfer weight and eliminate body flex this is the way to go.I think a quality poly will work fine (went down this road a long time ago)because the minimal transfer/flex reduction will be countered by the lack of weight in the rear.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
yep, I plan on doing some racing LOL
BlahBlahBlah
DIY4x4 has one inch aluminum body pucks that might work for you.
http://diy4x.com/cart/index.php?rout...product_id=174
