Old 02-24-2012, 12:21 PM   #1
1959 Apache 3600
1959 Apache 3600's Avatar
Red face Lose a leaf, change the shock?
Remember, I'm a old newbie, so be gentle...
Regarding my 3/4 ton, to lower it a bit, I'm considering removing a leaf from both front and back stacks.
  1. Which leaf do you suggest a guy remove?
  2. After removing a leaf, will I need to replace my shocks with ones of a different size?
Once again, thanks in advance for your help and suggestions
1959 Apache 3600 is offline   Reply With Quote
Old 02-25-2012, 12:14 AM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Lose a leaf, change the shock?
Remove the smallest one first. I doubt it'll lower it much though. You MAY need to remove more to get it where you want it. Some guys remove every other one. Unless you're loading it heavily (and you might since it's a 3/4 ton(?) you may not notice anything but a BETTER ride.
Dan in Pasadena is offline   Reply With Quote
Old 02-25-2012, 09:51 AM   #3
DransportGarage
DransportGarage's Avatar
The shocks are designed to handle full travel -- all the way to the positive rubber stop -- so they should not need changed. In general, if they don't bottom out at full travel (up or down) you are OK.
Bob
DransportGarage is offline   Reply With Quote
Old 02-25-2012, 05:24 PM   #4
1959 Apache 3600
Thanks guys... appreciate it!
