Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 02-25-2012, 01:39 PM   #201
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: D52 Caliper Rear Disc Brake Brackets
I need a set of these
pm sent
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 02-26-2012, 12:07 AM   #202
flamingbig10
6.0 powered square
flamingbig10's Avatar
I did with the brake best rotors but ended up going with duralast rotors no problem
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-26-2012, 12:08 AM   #203
Captainfab
60-66 Nut
PM returned and invoice sent
pm sent
Old 02-26-2012, 12:10 AM   #204
Captainfab
60-66 Nut
So the outside brake pad was rubbing on the Brake Best rotors but not on the Duralast rotors?
Old 02-26-2012, 12:17 AM   #205
flamingbig10
6.0 powered square
you got it
Aaron
Old 02-26-2012, 03:16 AM   #206
Captainfab
60-66 Nut
Thanks for confirming that. I have a customer that is having this problem, and I have been trying to figure out why. This is the first I have heard of the pad rubbing since the first few I made. I then made a change to compensate, and hadn't heard of this issue till now. I kind of thought it could be manufacturing tollerances with the pads and/or rotors.
you got it
Old 02-27-2012, 03:02 PM   #207
RdoubleU
RdoubleU's Avatar
Hoping CaptFab or someone else can lend some expertise/experience: I am wondering if I need to route new brake lines and if so what bore size to compensate for the change from drum to disks.
Basically wanting to make sure i have proper pressure everywhere needed.
Current Set-up:
- Front : ECE Drop/Disk Brake Kit
- Rear: CaptFab D52 brakes (with the astro van rotors and caddi e-brake calipers)
Master Cyl :
- Wilwood Manual Master - Part #
- 1" Bore (Same as Corvettes Ran) but i am going to call wilwood before ordering to be sure
Currently I have the stock Drum/Drum Lines front to rear
Should I route new lines either with a pre-bent kit or bend my own, and what size line should i be looking for?
RdoubleU is offline   Reply With Quote
Old 02-27-2012, 03:47 PM   #208
RdoubleU
RdoubleU's Avatar
Sorry Capt. Soon as I posted I thought it might be high jacking the thread
So I posted a new thread topic Here:http://67-72chevytrucks.com/vboard/s...22#post5216322
Thought it might help anyone else trying to run this setup also.
Old 03-01-2012, 10:46 PM   #209
chevytruckluver
Got the brackets today, Quality workmanship. Thanks John
Trey
72 Short Step
Old 03-02-2012, 12:02 AM   #210
Captainfab
60-66 Nut
Thank you for the purchase and the compliment Trey
Old 03-19-2012, 02:12 PM   #211
big d's red67
big d's red67's Avatar
how much for the D52 Caliper Rear Disc Brake Brackets shipped to 74014?
thanks Dennis
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 03-20-2012, 12:08 AM   #212
Captainfab
60-66 Nut
They're still the same price as in post #1.....$230.00 plus a flat rate shipping of $10.00. So a total of $242.00 to your door regardless of where you live in the USA.
thanks Dennis
Old 04-04-2012, 03:54 PM   #213
shearjs
shearjs's Avatar
Captain,
I'll be looking to buy some of your brackets in the near future. Are you still looking at producing the brackets and levers for the ebrake on the El Dorado calipers in the near future? Thanks for sharing all of your info. Much appreciated.
shearjs is offline   Reply With Quote
Old 04-05-2012, 01:41 AM   #214
Captainfab
60-66 Nut
I do still have plans of reproducing the levers and brackets. I did have some levers laser cut, but I've been so busy I haven't had time to finish them up yet.
Originally Posted by shearjs View Post
Captain,
Old 04-09-2012, 10:45 PM   #215
Nobby
Nobby's Avatar
Hey Capt,I sent you a pm.... I need some brackets...
Nobby is offline   Reply With Quote
Old 04-09-2012, 11:54 PM   #216
Captainfab
60-66 Nut
I replied to your PM.....
Old 04-10-2012, 05:22 PM   #217
Nobby
Nobby's Avatar
Payment sent Capt..Thanks
Old 04-16-2012, 05:09 PM   #218
Nobby
Nobby's Avatar
Hey Capt.Got my brackets in...Great product!!! One question, the "c'' bracket does not bolt flush to my flange on the rear end because theres a lip.See pics. Do I grind on the c bracket "hate to mess up powder coat" or do I put washers and shim it out?
Thanks,
Old 04-17-2012, 12:13 AM   #219
Captainfab
60-66 Nut
The base bracket is supposed to fit over the lip on the backing plate flange. Do not shim it out with washers....your caliper won't line up with the rotor. No one has mentioned this issue before. It looks like I may need to increase the diameter of the inside of the base bracket to allow more clearance for the powder coating. At this point, I would suggest reducing the diameter of the lip on the backing plate flange. This should be easiest done with a flat file, removing a little at a time until the base bracket fits. Then you can touch up the paint on the flange. The other option would be for me to send you another set of base brackets that have a larger inside diameter. Let me know, if you would rather go that route.
Old 04-17-2012, 07:46 AM   #220
Nobby
Nobby's Avatar
Thanks Capt, Thats all I need to know. I'll make them fit. Just didn't know if I had to shim them out. Again Great product and service!
Thanks,
Old 04-17-2012, 11:43 PM   #221
Captainfab
60-66 Nut
It's just the thickness of the powder coat that is making them too small. I thought I had allowed enough for that but apparently not. Looks like I need to make the ID on those another .010-.015 bigger.
Old 04-18-2012, 10:42 PM   #222
Nobby
Nobby's Avatar
I'll filed the flange just a hair and the brackets fit perfect.
Thanks,
Old 04-19-2012, 12:15 AM   #223
Captainfab
60-66 Nut
Cool.....I knew it shouldn't take much to get them to fit over that lip.
Old 05-09-2012, 02:47 PM   #224
RdoubleU
RdoubleU's Avatar
Capt'n - Any more thought or update on reproducing the levers?
I already have the brackets and being able to get the levers from you too and buy the reman calipers from a parts store would be a huge move forward for everyone
I haven't been able to locate any in a junkyard so this is my only current option: http://tsmmfg.com/3121.htm
Issues with the TSM calipers seem to be since they are New and not rebuilt calipers, TSM made some design changes so you cannot swap the calipers/brackets out from your local parts store with reman parts if you ever have any issues.
Old 05-10-2012, 12:13 AM   #225
Captainfab
60-66 Nut
Sorry about dropping the ball on this guys. Working 7 days a week just doesn't leave much extra time. I'll make a better effort to see about getting these done. I have the levers already laser cut, I just need to get them formed up.
RdoubleU, the brackets you mentioned, are those the D52 brackets you got from me, or are you talking about the e-brake cable brackets?
