Old 02-27-2012, 01:57 PM   #1
JCampbell
4L80E w/ Manual Speedo
Ouch. I just priced manual speedometer tail housings for the 4L80E. At over $500 bucks, I’m looking at other options.
Does anyone know if the ’91 trucks had electronic speedos? It sure seems like it would be much less hassle and a whole lot cheaper to swap in an electronic gauge cluster than to swap tail housings.
Anybody else run into this issue? What was your solution?
JCampbell is offline   Reply With Quote
Old 02-27-2012, 02:09 PM   #2
Jonboy
Slots go on anything!
Re: 4L80E w/ Manual Speedo
It is most 90 4wd and all 91's that had the electric speedo. If you are doing an LS swap (or LT1, for that matter), the PCM has the buffer built in, and is a single wire hookup.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 02-27-2012, 02:34 PM   #3
JCampbell
It's a TBI conversion.
Old 02-27-2012, 02:39 PM   #4
Jonboy
That may depend on the year of the ECM/PCM that you are using. The 90-91 trucks used a DRAC as a buffer for the signal. It is located under the radio. You may need that. I think if you are using a PCM, it may have the VSS out already in it (and then should be the 1 wire hookup).
Old 02-27-2012, 03:07 PM   #5
JCampbell
It's a 454/4L80E out of a '93 C-3500. From what I understand, that year uses the VSSB unit.
I did a little more research and I found a unit that converts the pulses from an electronic vehicle speed signal (VSS) into cable drive. For a "buy it now" price of $280, I'm thinking this is the way to go.
http://www.abbott-tach.com/cablex.htm
http://www.ebay.com/itm/Cable-X-3012...item4cfec995b1
Old 02-27-2012, 08:04 PM   #6
ghettoluxury
ghettoluxury's Avatar
You can use a 90/91 cluster with your 93 tranny.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-27-2012, 09:46 PM   #7
JCampbell
Good to know. Thanks.
