#51 | |
60-66 Nut
Re: my new 1963 GMC Suburban.........
Pat
I did a quick search on those heads, and they were used on the 300hp crate engine. Still a decent engine. I just wanted you to be aware that you did not have a 330 hp crate engine. As long as you're happy with it, that's what counts ![]() Quote:
#52 |
1# Drobmember in Germany
![]() Join Date: Aug 2008
update soon…….
Pat |
#53 |
60-66 Nut
Been wondering what happened to you Pat, haven't seen you post for some time. I'm anxious to see what you have to show us
#54 |
Hi Captain ,
i was busy all the time ,company and so on ....... but i made progress on the Suburban in the last 6month! hope to upload some pics this weekend!
Pat |
#55 |
very cool thread....nice truck
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#56 |
so guys i'm back with more pic's on my build ............
after storing the frame more than over a year outside it's time to get it back in my garage...... da Frame...... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() i'll running porterbuild dropmember front and rear !!! lets go.......
Pat |
#57 |
cutting out the old frame stuff and the first componets of the dropmember are going in ................
OLD ...... ![]() ![]() NEW.... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Pat |
#58 |
more new parts are going in .......
![]() ![]() ![]() ![]() ![]() the front end..... ![]() ![]() ![]() running a big brake kit with 13" rotors.... ![]() and the rear end with a 9" moser rear end...... ![]()
Pat |
#59 |
trying to build a nice exhaust system , but the first try are poor.......
![]() ![]() i think thats the better way to mount the muffler to the frame .... ![]() ![]() ![]() ![]() now hows the exhaust tube going to the engine??? RIGHT , cut holes in the frame and here we go...... ![]() ![]() ![]() ![]()
Pat |
#60 |
bought some Dodge 20" Steel rims to make some roller wheels for my chassis ......
Pat |
#61 |
and this are the wheels i'm running after this build......
Boss 308 in 20x8.5 and 20x10 , they are often to see in the US but here in Germany they're pretty rare....... ![]() ![]() ![]() ![]()
Pat |
#62 |
now back to the exhaust.......
![]() ![]() ![]() ![]() ![]() ![]() and here's the problem..... ![]() okay well i think i got it..... ![]()
Pat |
#63 |
and here the modified Transmission Crossmember.......
Pat |
#64 |
and the exhaust complete......
![]() ![]() and here can you see that i'm using a Tremec TK600 with a brandnew LS2!!!
Pat |
#65 |
here's the engine a LS2 2006 GTO and the Tremec Transmission .
some modification are necessary ....... ![]() ![]() ![]() changing the oil pan from GTO to Camaro .... ![]() ![]() mounting a new Fly Wheels and a new clutch..... ![]() ![]() ![]() test fitting of the bell housing and tranny..... ![]() ![]()
Pat |
#66 |
changing from manuel throwout bearing to hydraulic ......
![]() ![]() ![]() change to mid shift..... ![]() ![]() READY/WAITING for install.... ![]() ![]()
Pat |
#67 |
i made the radiator fit to the radiator support ,
its a Impala radiator with 3 row and dual fan assembly.... ![]() ![]() ![]()
Pat |
#68 |
cause i'm running the 9" rear end i had to modified the bar between the Trailing arms , the Rear end housing is bigger than our stock axles, here are the pics.....
![]() ![]() ![]() ![]() and there's the space i'm looking for.... ![]()
Pat |
#69 |
![]() Join Date: May 2007
WOW lots of updates of all the good stuff good job Pat.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#70 |
![]() Join Date: Sep 2011
I totally agree, I hadn't seen it before.
Herr Pat sehr güte, danke. Ich habe ein 63 4x4, siehe unten bitte. That is some awesome work, you have some mad skills. Mike
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 Last edited by MikeS.; 02-22-2014 at 07:54 PM. |
#71 |
Thanks Guys..........
here i welded the radiator support mounts to the frame , the stock one has rubber and these where in terrible condition. ![]() ![]() ![]()
Pat |
#72 |
I'm using the airride system from ACCUAIR and now i have to built some mounts to mount system to the frame ......
Pat |
#73 |
now it's time to make a bracket for the tank .
i'm using a tank from tanksinc.com ....... ![]() ![]()
Pat |
#74 |
now we have a rolling chassis and it looks good to me........
Pat |
#75 |
so now it's time for powder coating ..........
Pat |
