Old 02-29-2012, 11:42 PM   #1
woodwright
Enjoying left field
woodwright's Avatar
Alternate Heaters
Has anybody used an alternate heater setup from another vehicle in their trucks? I'm running a turbo, and don't have room for the fan and heater core housing. I'm not gonna run AC, and don't see the need for an aftermarket setup like Vintage air. There's gotta be an OEM setup that will fit well under the dash and provide good heat.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 03-01-2012, 12:06 AM   #2
70cst
70cst's Avatar
Re: Alternate Heaters
A bump for you ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-01-2012, 01:00 AM   #3
JKady
You can pick up a Summit Racing or Mojave heater for about 200 bucks brand new, compact units that put out very good heat and easier to fit than trying to cobble an oem heat setup into your truck.
JKady is offline   Reply With Quote
Old 03-01-2012, 02:15 AM   #4
woodwright
Enjoying left field
woodwright's Avatar
I've looked at the Mojave heaters, and I'm not really interested. I would rather spend $50 on a setup that I can make look like it was meant to be there.
Clint
Old 03-02-2012, 02:39 AM   #5
woodwright
Enjoying left field
woodwright's Avatar
Anybody? What about modifying the heater core box to lay flatter against the firewall?
Clint
Old 03-02-2012, 09:31 AM   #6
MrSchaeferPants
MrSchaeferPants's Avatar
Ya I'ma keep watching to see what you come up with. My defrost ducts are rigged right now, at some point I want to rip my entire heating setup out and do something else. But the opposite for me, I want it all out of the cab. I don't need a giant box with flaps. Just constant 50/50 defrost and floor. On, or off.
68 GMC C2500 - 305 V6 - 4spd
MrSchaeferPants is offline   Reply With Quote
Old 03-02-2012, 12:32 PM   #7
KrazyRay
KrazyRay's Avatar
Maybe you can get an early square body heater to work. The engine side of the firewall is pretty compact.
KrazyRay is offline   Reply With Quote
Old 03-02-2012, 01:39 PM   #8
jasons
not enough hours in the day
jasons's Avatar
I have one out of a 74 that I could get you measurements from if you wanted to see if it would work.
It is cable operated also, you may be able to make the original controller to work.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
& piles of spare parts
jasons is offline   Reply With Quote
Old 03-02-2012, 05:16 PM   #9
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
60-63 Chevy/GMC's had an "Economy heater" that the fan and core mounted under they dash, and only the heater core tubes went into the engine compartment. See post #5 for a picture.
http://67-72chevytrucks.com/vboard/s...economy+heater
Good Luck!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 03-02-2012, 05:25 PM   #10
Dano69c10
Dano69c10's Avatar
I'd like to see a pic of the "Economy Heater", and how it is mounted.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 03-02-2012, 05:33 PM   #11
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
The only pictures I see on that thread are in post #5, and #51. There are drawings of it on posts #32, and #50 if that helps any.
Jason
Old 03-02-2012, 05:38 PM   #12
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Here is a couple more.
http://67-72chevytrucks.com/vboard/s...d.php?t=367522
http://67-72chevytrucks.com/vboard/s...d.php?t=395492
Jason
Old 03-02-2012, 06:05 PM   #13
Dano69c10
Dano69c10's Avatar
Theres a good drawing in post 32, I think I'll try this in my '70
'69 Fleet
Old 03-02-2012, 06:11 PM   #14
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
There are some good pictures in the additional links I posted too.
Jason
Old 03-02-2012, 06:30 PM   #15
woodwright
Enjoying left field
woodwright's Avatar
Something else I might try is to rebuild the heater core box so the core sits flat against the firewall. I just need to gain 3 or 4 inches.
Clint
