![]() Join Date: Jan 2012
Is this really the best option for a master cylinder?
http://www.autopartswarehouse.com/sk...dot-80002.html
It's for my 1961 with an auto trans, no power booster and all drums. I guess I want to make sure I'm spending my money on the best option for my set up without moving up to a power booster system. Thanks, Scott |
Re: Is this really the best option for a master cylinder?
It's 70 bucks - hard to get killed to bad on that one. Check it out and let us know.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
#3 | |
It's more of a statement of performance for my current configuration rather than looking for the cheapest price. Mostly, can you use master cylinders from other, newer years that may perform better? |
Resistance is Futile
Were you planning on splitting the lines? I'm not familiar with the earlier trucks but I would split the lines if I were rebuilding. I used the 'Corvette' ms/cyl on my '66.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
![]() Join Date: Oct 2009
no prop valve needed, you are 4 wheel drums. 67 C10 MANUAL brake master cylinder works nice also. Will post a linky when I can find it - chief rocka has a good thread also.
here you go: http://67-72chevytrucks.com/vboard/s...d.php?t=487384 (also note chief rocka's thread is embedded at post #12)
#9 | |
thanks again. |
#10 | |
You can definitely do it for less than I spent on this set-up using factory parts.
#11 | |
I'll have to do some measuring and stuff and also add a plate to cover the up the clutch hole much like they did in this thread All the tips and pointers are much appreciated. |
Tags |
brakes, master cylinder |
