Old 03-03-2012, 07:03 PM   #1
c50rob
Tailgate trim installation
I have installed the chrome center piece above the tailgate latch, my two upper molding pieces are either too long and need to be cut off, or they need to go over the outer edges of the chrome above the latch. If it is to be cut what is the best way too cut the trim without damaging it? Also what size drill bit is used for installing the clips?
c50rob is offline   Reply With Quote
Old 03-03-2012, 07:18 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Tailgate trim installation
The two side trims should lap over the handle trim...maybe ~1/4" each side.
On hole size, mine are 1/4" and the holes for the tail light trim is larger (forgot to measure).
ETsC10 is offline   Reply With Quote
Old 03-03-2012, 07:20 PM   #3
67chevy1series
67chevy1series's Avatar
i have done this install to my tailgate as well.... i dont remember the drill bit size.... however i do know how to shorten trim... what i do: if i have to trim more then 2 inches, i cut it with tin snips about 1/2 inch away from my line then i take a grinder and rind it all the way to my line or you could say my "desired length".... thats worked for me.
67chevy1series is offline   Reply With Quote
Old 03-03-2012, 08:34 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Like ETsC10 says they overlap. You push the end of the trim over the center piece. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-03-2012, 09:33 PM   #5
c50rob
Thanks for the replies, I guess in the morning I'll install, my main concern being if the trim overlaps the latch trim it will not set flush to the metal where the two seperate pieces meet.
Old 03-04-2012, 12:44 AM   #6
pat 70/71
pat 70/71's Avatar
The center piece is tapered for that very reason you just install the clips in the tail gate and slide them on from each side until the mounting bolts line up with the holes then bolt em up. I didn't have to cut mine. Be careful when you push the trim on the center piece so you don't bend it. cheers, Pat
pat 70/71 is offline   Reply With Quote
