03-04-2012, 02:19 AM | #1 |
Aftermaket inner fenders and rad support fitment problem
Anyone seen a similar problem with fitment on these parts ? Everthing bolted up finger tight at the drivers side and seems ok (less the 1/4 gap between the rad support washer and pad),so here are some pice of passenger side with bolts finger tight and rad support at mounts finger tight.....not good.
If anyone can enlighten me ? Need length measurement of oem inners end to end for start,and also if this is a common problem ? I might take these back and look for some oem inners that I can repair.
Always a place in my heart for old Chevy trucks: My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 |
03-04-2012, 02:36 AM | #2 |
Re: Aftermaket inner fenders and rad support fitment problem
Ya repo sheetmetal parts are junk, dont buy them and waste your money or time is the general outcome.....many threads on them check this thread out:
http://67-72chevytrucks.com/vboard/s...ht=repo+fender
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
03-04-2012, 07:54 AM | #3 |
Rottenwood Garage Member
This is the case most of the time. You will have to finess it together, alter holes and make changes for it to work.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
03-04-2012, 09:37 AM | #4 |
Resistance is Futile
In other threads it was mentioned that the inners were different lengths.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-04-2012, 10:47 AM | #5 |
I think you better read my blog in this same section. It is called How do you fix this? Repo body parts. I have been down this street, and it's not a very nice ride. I still have a bit more to fix. Mine are TriPlus, and you will see some of the suprises you are in for on my blog.
03-04-2012, 08:19 PM | #6 |
I just pulled a set from pick-n-pull this week. If you run a tape along the outside edge, it's right around 35 1/2 inches. If you run a tape along the raised ridge, it's right around 36 1/2 inches. Hope this helps.
03-04-2012, 09:19 PM | #7 |
why can't you tighten the bolts up? the rad support has rubber washers, it should pull together. in the top picture the 3rd bolt down looks to have a washer and nut between the inner fender
03-04-2012, 09:21 PM | #8 |
make sure you run a measurement diagonally corner to corner to make sure inner and support are square to body and parallel.
03-04-2012, 09:52 PM | #9 |
The reason he can't tighten the bolts up, is because the lower backet in the front is already bottomed out. It has to be relocated for the rad support and inner to go together tight, with the bracket to be bottomed out also. It was the same on mine.
03-04-2012, 10:55 PM | #10 |
But Found Her 25yrs Later!
Please forgive me if it's a stupid question, but do you know if the cab is mounted too far back?
03-15-2012, 04:08 PM | #11 | |
Hands down ....,the aftermarket panels are junk.One of my bodyman buddies has some of these type panels in the corner of his shop...,he cuts 3"and 4" pieces out of them for patch work,that's all there good for. Cheers, Ed.
03-15-2012, 04:10 PM | #12 |
You gotta be kidding !
Always a place in my heart for old Chevy trucks: My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 Last edited by lenguini; 03-15-2012 at 04:10 PM. Reason: spell |
03-15-2012, 04:32 PM | #13 |
Wow-I bought an aftermarket fender 10+ yrs ago, sent it back. It's hard to believe they still don't fit-you would think in 10 yrs time somebody would figure out how to stamp them properly.
03-16-2012, 12:27 AM | #14 |
60-66 Nut
They aren't going to change the quality of the parts because too many people keep buying their parts the way they are.
