Old 03-04-2012, 03:43 PM   #1
savatreatabvr
savatreatabvr's Avatar
SUCCESS!!! BBC Valve Seal Replacement!
I successfully replaced a intake valve seal with the head still on the engine! I did it the traditional way with a valve spring compressor and a piece if rope! I didn't realize how easy it was but I still only replaced the one, the best part is the BBC doesn't smoke anymore!
savatreatabvr is offline   Reply With Quote
Old 03-04-2012, 05:21 PM   #2
burb1085
burb1085's Avatar
Re: SUCCESS!!! BBC Valve Seal Replacement!
Ya, I have to get around to doing mine also. Did you use the umbrella type seals? Aprox. how long does it take? I have an 87 454 TBI, It's my daily driver, so I'd have to make it a week end job.
burb1085 is offline   Reply With Quote
Old 03-05-2012, 01:05 AM   #3
BigRed76
BigRed76's Avatar
What is the trick with the rope?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 03-05-2012, 03:35 AM   #4
Littletony
Littletony's Avatar
You pull the spark plug and fill the cyl full of rope to hold the valve up.
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945
Littletony is offline   Reply With Quote
Old 03-05-2012, 12:15 PM   #5
Desert1957
Desert1957's Avatar
Is this the follow up post to your oil consumption/valve seal thread?
http://67-72chevytrucks.com/vboard/s...19#post5167719
Desert
PS: Good Job!
Desert1957 is offline   Reply With Quote
Old 03-05-2012, 06:45 PM   #6
savatreatabvr
From start to finish it took around 30 minutes to replace one umbrella style valve seal! The trickiest part is getting the spring compression tool lined up just right so the spring doesn't come shooting out like a bullet, just be careful and you'll be alright!
Old 03-05-2012, 06:49 PM   #7
savatreatabvr
The rope keeps the valve pushed up, bring the piston to TDC and stuff the cylinder full, the valve must be all the way up or you won't get the keepers off or back on! You can also use an old spark plug wire or compressed air!
Old 03-05-2012, 06:50 PM   #8
savatreatabvr
Yes it is!
Desert
PS: Good Job!
Old 03-05-2012, 09:16 PM   #9
1425956
1425956's Avatar
Is the process the same on a SBC? My truck smokes a little when you first start it up or if it has been idling for an extended period of time. The truck sat for 10 years without being started once. It has 83,000 miles on the truck and original 305.
And congrats on your success story!
Jeremy
I have done so much, for so long, with so little, I can do anything with nothing!
1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.)
1986 GMC Suburban 3/4 ton 4x4
2014 GMC Sierra LTZ Z-71 Crew SWB
1425956 is offline   Reply With Quote
Old 03-05-2012, 09:50 PM   #10
savatreatabvr
It's the same! My 454 didn't smoke at start up but did if idling for a while so I'd think you're issue is the valve seals and not the piston rings!
Old 03-05-2012, 09:55 PM   #11
savatreatabvr
I don't plan on doing the other valve seals until they go bad simply because I believe in the old saying, "Don't Fix It If It's Not Broke"!
Old 03-05-2012, 10:02 PM   #12
1425956
1425956's Avatar
You said you only replaced one seal and now your engine doesn't smoke anymore. How did you know which one to replace? I would think if one is bad (dried out), they all would be.
Jeremy
Old 03-06-2012, 01:52 AM   #13
savatreatabvr
Only one cylinder was oil fouling the plug, #4.
This is what it looked like before replacing the valve seal!
