03-04-2012, 06:33 PM | #1 |
starter? cap? ghost?
Whats up guys...
a few weeks ago I was having trouble starting my truck.. I found a problem with the rod in my column and thought everything was OK.. Now it's having trouble again... some times it fires right up.. other times it acts like the battery is dead even though it's not.. after a few turns (all like the battery is dead) it will fire right up... Starter? Could it be a problem with my distributor, cap or wires? I was reading online that auto zone can test my alt, bat, and starter.. true? every time I have been in there they look lost.. like they woke up in the back room and don't know how they got there... lol... thanks for any tips...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy? |
03-04-2012, 07:19 PM | #2 |
Re: starter? cap? ghost?
sounds like bad connections or solenoid. clean up the terminals on the ign system
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
03-04-2012, 08:03 PM | #3 |
Could be a bad starter or bad cables.
Does it act differently when the engine is hot or cold? Posted via Mobile Device
CHEVY ONLY |
03-04-2012, 08:13 PM | #4 |
Robert Olson Transport
first thing you do is clean every connection in the starting system incuding grounds .On all the battery cablesinspect for corrosion , cracks etc ill bet youll find your culprit..
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
03-04-2012, 08:14 PM | #5 |
Check the battery cables,and while you're at it,check to see if the solenoid is loose,on the starter.
I've seen a couple'so far,especially on autozone/O'reilly's starters!
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
03-04-2012, 08:55 PM | #6 |
Have you checked the ignition switch at the column? You know where the rod connects. You can loosen the screws and slide the switch further down the column, maybe the rod from the key isn't pulling far enough to engauge the starter circut.
03-05-2012, 12:09 AM | #7 |
Thanks for the input everyone... last week I replaced the key with a push button, checked column and rod, also swapped out the battery terminal connections.
today at your guys advise I traced all wires, made sure everything was clean and tight... I just got back from Auto Zone and they said that my battery was good, alternator was good and....... my starter failed..... It was looking that way anyway.. So probably a safe bet huh? Looks like I have a new starter in my future... Any recommendations??? again thanks for the input everyone... .
03-06-2012, 12:17 PM | #8 |
78K & 79C Jimmys
i've seen the big batt post on the starter solenoid get baked inside
sometimes removing the cap there, it can be turned to work again but when i did mine the flywheel was part of the problem (worn out)
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-06-2012, 12:21 PM | #9 |
^^who I am^^ what I say>
Ive had starters work fine until the truck gets warm, and then they get heated and wont work; it acts like the battery is dead. I have that problem with my 4x4 right now.
I would recommend just getting a lifetime replacement starter from your favorite parts house, that way if it goes out again, its their problem!
70 chevy LWB 350/TH350 Barn find (AKA the 70) http://www.67-72chevytrucks.com/vboa...d.php?t=406364 East Tx Squares |
03-06-2012, 12:49 PM | #10 |
My two year old tells me "ride the truck, cool...."
So... I tell him if it starts will take the truck.. thinking I'll just leave it running at the parts store.. I go to Orileys get the lifetime starter.. figure even if it craps out, it's not too hard to get too.. On the way home it feels like I'm out of gas.. I have gas though... And dead on the side of the road.. Pretty sure My fuel pump took a crap.. Oh the joys of truck builds... lol....
03-06-2012, 01:06 PM | #11 |
a pump is all of 20 dollars and a 30 minute job, get it done
03-06-2012, 01:11 PM | #12 | |
03-06-2012, 01:34 PM | #13 |
I was going true the same thing you are just last week on my 95 some times it start right up then it would give the impression of a dead battery it was the starter I picked up one from Napa for $60 solved my problem
03-06-2012, 02:12 PM | #14 |
An electric pump wouldn't be a bad idea, but usually they'll give signs before they completely crap out
03-06-2012, 02:29 PM | #15 |
78K & 79C Jimmys
just don't add an "extra" pump like my PO did on my 79,what ever works eh
with a few extra pieces lol if you find leaning over the side, bad pull the inner fender,sit on the tire kept my backside out of the -20C heat lol
03-09-2012, 01:16 PM | #16 |
new pump, new starter fires right up... thanks for the input everyone...
