Gas filler neck hole cover?
I went ahead and relocated a 78 blazer tank behind the rear axle on the 65 lwb, as an after thought. I have already painted the truck, so I can't just weld the filler neck hole shut at this point. Any cleaver ideas on how to cover the hole up? My plan so far is to remove the in cab tank, and clamp the original filler neck into place so it looks like the tank is still there and for added insurance, use a locking gas cap to make sure someone doesn't fill my interior up with gas. It's the best plan I have so far, what do you guys think I should do?
Opportunity usually comes disguised....As hard work!!! ![]() |
![]() Join Date: Nov 2010
Re: Gas filler neck hole cover?
put a bottom on the filler neck and have a locked cubby hole
2003 Serria K1500 1998 Camaro 1964 C10 long fleetside bed, small back window, 3 on the tree 1964 C20 custom cab, long fleetside bed, big back window, 4 on the floor Disclaimer- anything posted is only based on my personal experience, opinions, and advice given by others. There are no implied or written warranties or guarantees with anything posted on this website. |
Enjoy your truck
I used the stock grommet and filler neck, and the rubber coupler that attatches to the tank. At the bottom of that assembly I put in an abs plumbing cap (can't recall what size). It is hose clamped onto the rubber coupler.
On the outside I epoxied onto the metal filler neck a gas cap that I made from a horn button from the standard steering wheel from our trucks. No way you can accidentally fill my cab with fuel. Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
take a spray can cap and wrap some shop rags around it and cram it in the hole. gives a wtf vintage look. did it to my old 64, you can see the effect on you tube search; dave's airride chevy truck
[IMG]
![]() [IMG] ![]() [IMG] ![]() And then a little paint.. There is no way someone can fill your cab with gas now..... ![]()
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
Any other ideas on how to fill stock hole after relocating fuel tank...
Thought about using part of stock tank tube with locking gas cap. Hate to mess up a good inside tank...but what do you do?
![]() Join Date: Jan 2011
I machined a plug out of a piece of 3" aluminum. One end looks lust like a gas cap and then it necks down to a little bigger than the stock tube. Put it in with a new rubber grommet and just a touch of super glue. With it painted white it looks just like a stock cap and with it being a piece of solid 6061 no chance of any one getting the cap off.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
I jb welded a stock looking cap to the end of mine and painted it the same color as the body.
Senior Enthusiast
I beat a piece of old fender into a patch that fit inside the body, and adhered it with JB Weld. It's been in place for 18 years and still looks like it was just put in place:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
![]() Join Date: Sep 2006
I removed my tank and left the cap/fillerneck in place. No clamping needed.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
He said "I have already painted the truck, so I can't just weld the filler neck hole shut at this point"
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
I did the same... just left the filler neck and cap in place.
I'm just gonna leave the filler neck in too
#15 |
![]() Join Date: Nov 2012
In 1965 American LaFrance Fire Engine Co. removed the cab tank and added a 50 gallon tank under the rear frame. They put in a chrome plated button plug in place of the filler tube. It's still there in my C80 truck.
