03-08-2012, 09:39 AM | #1 |
Vapor canister lines
i was putting my order together for Inline Tube, and i see they have Vapor canister lines. Should i be runnig a vapor canister with the 454? I dont think the 72 had one on it when i got it. I know the 71 does. Not alot of time spent on using them.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
03-08-2012, 11:54 AM | #2 |
Junior Member
Re: Vapor canister lines
I did not have the lines hooked up to the vapor canister on my '71 with a 454 and it ran fine.
I just left the vapor canister line hooked up to the tank, but open ended under the truck to allow the tank to vent.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
03-08-2012, 11:23 PM | #3 |
Scrapper 1
I was told a long time ago the Vapor canister help with gas mileage keeps the tank from pressurizing and it keeps back pressure
03-09-2012, 08:52 AM | #4 |
I did some reading on it, i guess i should keep it, with the new rear tank, i'll just run a longer line.
Thanks guys
03-10-2012, 10:37 AM | #5 |
Sierra Grande Club
I wonder if that's my problem with poor MPG. I'm hooking it back up!
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
03-20-2012, 11:53 AM | #6 |
Apparently, old school hot rodders say do away with the canisters, and mechanics say keep it because it will aid with MPG.
03-20-2012, 12:27 PM | #7 |
03-20-2012, 12:40 PM | #8 |
Florida Edition
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
