Old 09-13-2003, 04:23 PM   #1
zyggy72
Can't kick the addiction!
2" suspension lift in a 67-72 2wd truck?
Anybody do a suspension lift on a 67-72 2wd truck? How did they go about lifting the front? Any parts, pics, ideas, suggestions? At this point anything will help.
zyggy72 is offline   Reply With Quote
Old 09-15-2003, 11:23 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
See pics in sig link. 2" heavy duty tuff country springs up front. Removed factory block(approx. 1") in rear and added 2" block and an add-a-leaf. Actually got about 3" of lift, nothing has settled. I've had some hvy loads since installing lift (2 tons sand, 1800lbs concrete pipes a couple others) real pleased with results.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 09-15-2003, 02:21 PM   #3
67'ShortMonster
Keep in mine that 67 and 68 had longer springs in the rear. A 69 to 72 "kit" will not fit these two years on the rear of a 4x. You can move the spring hanger... or buy custom springs.
67'ShortMonster is offline   Reply With Quote
Old 09-16-2003, 08:35 PM   #4
Dusti
Not Dusti,just Bob
Dusti's Avatar
zyggy72 wants to lift a 2 wheel drive not a 4x4.
Not sure how you would lift a 2 wheel drive.the back you could use blockes but not sure obout the front.
Bob W
72 cheyenne super 1/2ton
89 camaro
Dusti is offline   Reply With Quote
Old 09-16-2003, 10:08 PM   #5
67'ShortMonster
LIFT A 2WD TRUCK ? Now that is confusing... Why...?
Old 09-16-2003, 11:38 PM   #6
Dusti
Not Dusti,just Bob
Dusti's Avatar
[QUOTE]Originally posted by 67'ShortMonster
LIFT A 2WD TRUCK ? Now that is confusing... Why...? [/QUOTE
Good question.my 3/4ton sits up high enough,I have had people ask me if it 4-wheel drive
Bob W
89 camaro
Old 09-18-2003, 02:55 AM   #7
zyggy72
The front of my 3/4ton squats pretty low and with the new rearend setup that I am putting under her makes the nose point toward the ground. The rear of the truck is raised about 3 - 4 inches with the new rearend setup and I would like to lift the front at least 2 inches to nearly even her out. I also prefer to have to get up into the truck than have to sit down into it.
Old 09-18-2003, 10:02 AM   #8
Custom 68
Custom 68's Avatar
Your front springs may (probably) are just worn out. a PO may have heated or cut them.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-18-2003, 03:23 PM   #9
stepn67
Junior Member
stepn67's Avatar
Front End Lift
I put a set of block springs on the front of my 67 and got about 2 inches of lift.
stepn67 is offline   Reply With Quote
Old 09-19-2003, 11:34 AM   #10
stepn67
Junior Member
stepn67's Avatar
2wd lift
That should read "Big Block Springs" not block springs - BTW I did this on my 67 1/2 ton just to level it out a bit without dropping it, but am now working on dropping it all they way around.
Old 09-19-2003, 04:36 PM   #11
zyggy72
I was considering replacing my springs with the 1-ton/big block springs anyway, I was wondering if there were other options.
Old 09-20-2003, 05:50 AM   #12
Linus0014
Guest
Posts: n/a
Eaton Springs will make you a set of coil springs that are just like the originals in your truck with 2'' lift for 159.00
Old 09-20-2003, 08:58 AM   #13
zyggy72
Cool, thank you Linus0014, I will definitly look into those Eaton Springs.
Old 09-20-2003, 01:44 PM   #14
Linus0014
Guest
Posts: n/a
www.eatonsprings.com
Old 09-26-2003, 07:57 AM   #15
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
RANCHO has a 2wd lift kit for 73 and up that may work with 72 and down. Seen it in a classic industries catalog.
Old 10-05-2003, 02:26 PM   #16
pooz911
pooz911's Avatar
I have the Rancho front springs installed in my 1971 3/4 ton 2wd chvy and a 3 inch body lift on 33 inch bfg mud terrains.... I f you need any info, let me know.
Jim
pooz911 is offline   Reply With Quote
Old 10-20-2003, 05:28 PM   #17
Linus0014
Guest
Posts: n/a
Just in case you guys didn't know, you can use 73-87 upper/lower control arms, springs, spindles, outer tie rods, control arm bushings, and ball joints. If you use these items, you need to use all of them at once, meaning you cant do upper/lower control arms w/o ball joints........They will bolt up with no special welding or whatever.....
