03-08-2012, 09:59 PM | #3576 |
Re: What did you do to your truck today!
Are the spintechs louder than Flowmaster super 44's, maybe less chambers or something to be so loud.
03-08-2012, 10:01 PM | #3577 |
03-08-2012, 10:42 PM | #3578 |
Getting them ready for paint... Hopefully I'll paint them Sunday Posted via Mobile Device |
03-08-2012, 10:57 PM | #3579 |
After more than five years of having my project on standby(got married and a bb) i started my truck and it fired on the first try.(fresh gas) But it would not move, check the trans fluid and it was full of water. You can see my avatar pic that was like 6 years ago we got hit by a hurricane. Will I have to replace the trans of just the fluid and filter?
03-08-2012, 11:25 PM | #3580 |
I have spintechs on my 2004 z71. I was told that some guys from flowmaster went and made their own muffler, not 100% on that. I would compare them pretty close to 2 chamber flowmasters or the 40 series....They sound pretty good and the noise level is about the same.
03-09-2012, 12:47 AM | #3581 | |
optomistic ah-so
I'd check the engine and rear gear fluids, too.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
03-09-2012, 01:06 AM | #3582 | |||
I have a few videos posted, I'll see if I can find one.
Here are a few videos I found that I have posted in the past, not the best, but you can hear what you need to in them. |
03-09-2012, 08:31 AM | #3583 |
Sound sick. What engine? And which spintech? Looks like sportsman 3000
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant Last edited by BigCountryx; 03-09-2012 at 09:04 AM. |
03-09-2012, 01:06 PM | #3584 | |
Also, let's clarify something here...I'm not opposed to the sound of my truck, it's just the raw decibel level is fairly high. Everyone that sees/hears my truck just loves it. But, as an example, I live about 30 miles from work and I generally don't even listen to the radio due to the exhaust from the truck. A couple of things I noticed is your exhaust appears to be a little smaller, but it also exits at the rear tire. My exhaust turns down right in front of the rearend and I think it keeps a lot of the sound under the truck! Wonder where I can borrow a camcorder???
don "The DRBMan" 2014 Audi A4 (The Wife's Daily Driver) 2017 HD Ultra (The Cruiser) 2003 HD Fatboy (The Ride) 2001 Chevy Suburban (Another back up!!) For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!! |
03-09-2012, 04:43 PM | #3585 |
Added a side post battery quick disconnect to the bagged silverado so I could disconnect the battery when it sat for a while
03-09-2012, 07:05 PM | #3586 |
Tried to install antennae, but they sent me the wrong one. Bummer. Resplicing the steering harness next.
I know I can! I know i can! 72 K20 Restoration |
03-09-2012, 08:14 PM | #3587 |
Replaced my broken under-dash brake pedal return spring. Was a bear to get to.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
03-10-2012, 11:42 AM | #3588 |
Tried to get my camera's video capability to pick up the sound of the truck. Apparently there was some serious tonal distortion and the sound was not good at all. Tested my phone to see if it would work and it was marginally better. So, let's see if I can embed the little clip I made yesterday.
Here's the sound from the headers, 3-inch pipe, and SpinTechs... After hearing the recorded sound of my truck, it helped put the AustinScott videos in better perspective. My truck does have a good tone, maybe it's just my ears!! lol
don "The DRBMan" 2014 Audi A4 (The Wife's Daily Driver) 2017 HD Ultra (The Cruiser) 2003 HD Fatboy (The Ride) 2001 Chevy Suburban (Another back up!!) For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!! Last edited by dhaymaker; 03-10-2012 at 11:53 AM. Reason: Adding some thoughts... |
03-10-2012, 11:49 AM | #3589 |
started the install of my drop. Started in the rear last night, removed shocks, springs and the upper spring brackets so far......
1971 chevy c10 ECE 4.5/6 dropped 1970 suburban ECE 4/6 Dropped 45K original miles so far 1948 Ford Sedan 1941 Dodge COE 1932 ford roadster the rest are normal drivers |
03-10-2012, 11:51 AM | #3590 |
Going to finsh up my rear disc conversion and finsh replacing front metal brake lines , but the prebent line i bought is gonna make me remove drivers side header so i can get it in. should have done all this before i finshed the truck,
03-10-2012, 02:05 PM | #3591 |
Spintech 3" exh sounds good dhaymaker, but with exhaust it really comes down to the cam and you def have enough, sounds really nice, better in person I bet.
03-10-2012, 04:19 PM | #3592 |
Finished replacing the 200 4R with a TH350 in my Burb. Road tested it and it seems to work well.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
03-10-2012, 04:31 PM | #3593 |
Got my engine mocked up to make sure all the parts will fit... looks like i will have to do a little trimming to allow clearance for the bolts.
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
03-10-2012, 04:34 PM | #3594 |
dhaymaker that sounds awesome!
03-10-2012, 04:34 PM | #3595 |
Hey longbed looks good always wanted to do that to a straight 6, i really like to hear that when you get it done.
03-10-2012, 04:39 PM | #3596 |
I installed some arm rests from a 55-66 chevy truck and new sunvisors that I ordered from Classic chevy parts. I also cleaned up a A/C control panel I bought at a swap meet a couple weeks ago. Also test fit a new bench seat and new foam, taking it to an upholstry shop next week.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake 1968 C10 flatbed 307 w/ 4 spd manual (dads old ride) 1936 1/2 tn pickup, 400sb 350 turbo (partially restored) 1949 1/2 tn, needs complete restore (future project) 1969 Chevy impala 4 dr no post (wifes future car) 2010 GMC Serria 4x4 crew, leveling kit |
03-10-2012, 04:41 PM | #3597 |
Fldawg I will definitely post up a few videos when she's up and running!
03-10-2012, 05:08 PM | #3598 |
Took out radiator, fan housing, headlights, and then after a lot of screaming stopped because of the stubborn bumper...I know it can be removed, just not today
Mac 1970 GMC SWB 1971 Chevy C-20 Longbed Driving Miss Maybel: http://1970gmctruck.wordpress.com/ My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=513475 |
03-10-2012, 05:30 PM | #3599 | |
NICE Truck!! The exhaust on my truck when I first put it together exited under the truck (turn-downs before rear axle) it was to loud in cab, so I had the current setup fabbed up that exits out the side. The sound in cab was cut in half. I bet if you just had the end sections re-done to exit out the back or rear you would be much happier with the exhaust note. -=Scott=- |
03-10-2012, 05:38 PM | #3600 | |
Spintech's = Sportsman-3000 2.5" in/out These videos where taken only a few days after getting the exhaust put in. They have had some time to "mature" (fill with carbon) any they are a tad bit quieter now after a year or so of running with an overly fueled engine. -=Scott=- |
