Old 03-10-2012, 10:34 PM   #1
62 Bowtie
62 Bowtie's Avatar
Air Distribution
Question for you bag guru's How do you know your air is distributing evenly?I dont have guages, I know I know, but my problem is not ride height its more a uneven level. I have 2 Viair compressors accuair vu4 manifold with avs 7 button sw when i hit the center rear sw the left goes higher than the right the front is ok ss7's up front could it be the bags? i got the rears on CL RE8's maybe too big? Also 3/8 line cut to same length at rear and in front with manifold centrally located, thanks dudes
62 Bowtie is offline   Reply With Quote
Old 03-10-2012, 11:17 PM   #2
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Air Distribution
wow didnt know you had the vu4 manifold
Sick5 is offline   Reply With Quote
Old 03-11-2012, 01:59 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Sorry bro, but you need gauges to know whats going on. Its not uncommon for a bag to require more pressure than the other to set at the same height. It could be the bag, or the suspension, but you won't be able to track it without your gauges
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-11-2012, 07:44 AM   #4
andrewmp6
Is it like that no matter where you park it?It might even be the ground isn't level.
Old 03-12-2012, 12:09 AM   #5
62 Bowtie
62 Bowtie's Avatar
well that does bring up another point when I air out sometimes its crooked too with no air youd expect it to be level the rear bags are used im gonna start there and put new bags
Old 03-12-2012, 02:18 PM   #6
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
are the brackets for the bags the same highet and by how much of a diffrents is it
Old 03-12-2012, 09:06 PM   #7
62 Bowtie
62 Bowtie's Avatar
Yes the brackets are the same and it varies sometimes its fine and sometimes its about 3 in difference
Old 03-13-2012, 04:26 PM   #8
tubbedII
needs more $$$
tubbedII's Avatar
Is it always the same side that's lower? I'd pull apart the lines on that side and make sure there's nothing potentially clogging it/slowing it down. I don't think the bags themselves would be causing this and it would have to be a pretty bad binding issue if the same pressure is going into the bag. They'll probably never be perfect, but 3" difference is pretty excessive.
Have you driven the truck? I'm curious on how the ride is considering the bags are mounted so close to the pivot and your shock locations. I'd like to do something like this on my blazer to get a few more inches of drop and still keep the bench.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 03-13-2012, 09:36 PM   #9
62 Bowtie
62 Bowtie's Avatar
Yes i drive it all the time and it rides great
Old 04-07-2013, 07:49 PM   #10
Square_78
Square_78's Avatar
Did you figure this out?
I have a similar issue on my front bags. Passenger side lifts faster than the driver side. Everything is new. No binding or rubbing that i can see. I have a manifold system.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 04-08-2013, 12:45 AM   #11
wraprail
wraprail's Avatar
Since this was dragged up from the dead, I have a question. I agree about the guages, just courious how the accuair guys manage?
Does it matter if your air lines (3/8) are the same length or not?
wraprail is offline   Reply With Quote
Old 04-08-2013, 02:23 AM   #12
62 Bowtie
62 Bowtie's Avatar
Well i still dont have guages yet! but plan too i just get out of my truck and set cruise height for now accuair is cool no probs i cut to equal length just cuz i thought i should not sure if it matters
Old 05-01-2013, 08:59 PM   #13
Square_78
Square_78's Avatar
I talked to Accuair tech before and they said the lenth of air line makes little to no difference side to side.
#teamlongbed
Old 05-14-2013, 09:44 PM   #14
CRGRS 66
CRGRS 66's Avatar
Maybe you have a mechanical binding issue, the bags do look to be unusually near the front of the truck, perhaps there is some issue with cantilever, maybe the bags are the fulcrum in a teeter totter. I am no expert, but thought i would offer some food for thought. Cheers, good luck.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
