#26 |
Re: Straight to the track! 383 or 408?
shorter deck blocks will help some in acceleration. I like the old school stuff as in original style blocks or ''mid deck'' blocks. If you can locate used splayed valve or or SB-2 heads this will be the meanest stuff you can get. If you add nitrous ,turbos or whatever this will be the most powerfull. These heads make power real high in the rpm range so your limited as far as street driving and you trailer to the track. I helped a guy with a 427 mid deck splayed valve set up for 2 kits. It made over 1000 hp without nitrous. This was 10 years ago so you should be able to find some of that stuff pretty cheap now. I have seen 375 inch comp motors make 1,100 with the same type of set up. I have always liked good used comp eliminator parts because you know it will make power.
#27 | ||
Truck and auto performance nut
or.........if you are stuck on a sbc stye short block but like the flow numbers of LSx heads:
![]() ![]() ![]() Quote:
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#28 |
Warhawk LS - aluminum LSx block
![]() Motown LS (sbc short block) ![]()
#29 |
68 I did read about that but have never seen one done.. , gotta say cool.
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
#30 |
world products built one on one of the rags ....can't remember which tho. A LSX with the same heads and cam, etc......the Motown LS made just a tad more power. Can't remember why tho. damn meds!
#31 |
I spoke to a guy at the show with a 454 SBC he is going on about how much power it made.. 679 at the flywheel, I ask about the engine he has almost no idea what is in it really, and then tells me " well these headers and intake and carb are not what was used to dyno the engine" He liked the looke of this carb better, and this intake is a nicer looking item and the headers blah blah " I just smiled and walked on... Funny I got 679 HP but I changed the parts but hey it made 679 HA HA ... Too bad marv was not there... lol ... he would have loved that guy .
#32 |
more money then since
#33 | |
mini truck racer
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
#34 |
Champagne Taste on Beer Budget
World Products has some very nice go fast goodies.
Coming Soon: Project 1970 Country Truck |
#35 |
There seems to be a large sway either way for or against world stuff. I do not know what that is about. But it does seem they are trying new things and working on bringing items to the table that others do not..
Another shop built a ols style SBC with LS intake and hemi heads. I ran across that in the good guys magazine.. One thing I do know is that the hybrid stuff is very spendy.. to the point where one would have to think about the build vs just building a real ls engine.
#36 |
I think the main reason for it is for guys that either have to run a sbc shortblock or because they have to run a carb and a dizzy...because of their racing class rules?
...and yes....there's a GMPP water pump setup you can run that provides for a front mount dizzy for the LS...like a f*rd.
#37 |
Running in a "class" would change things, I was more thing ET class pro.. so anything you want just dont run under a 9.99 unless you have the full cage etc. Up to that point not hard to run very fast for a street vehicle. I am setting my truck up for that and the rules are pretty basic. I have to added a few things but nothing major, unless I run under the 9.99 then its gets more complicated. But hey you also get the one freebie after that its shame on you..
#38 |
I don't plan on mine ever getting that fast....12's is the mark so its possible I'd wind up in the high 11's but certainly no faster. Trying to keep all motor...if not just a small shot.
This truck already has a future owner...my grandson!
