Old 09-14-2003, 10:34 AM   #1
Shane
Shane's Avatar
For Sale: N.O.S. GM 3.73 ring and pinion
Brand New ... Never Installed.
Bought these a year or so back for a project that got changed around, decided to use 3.08 ratio instead ... so now I don't need these.
A friend of mine who works at a local Chevy dealership found these on the shelf at another dealership thru their computer parts locator.
If no one here is interested, they will go on eBay ... but wanted to give ya'll "first dibs" on them.
$150 plus shipping.
Email or PM with any questions.
Shane is offline   Reply With Quote
Old 09-14-2003, 10:34 AM   #2
Shane
Shane's Avatar
close-up of box
Old 09-14-2003, 10:35 AM   #3
Shane
Shane's Avatar
close -up of ring gear
Old 09-14-2003, 10:35 AM   #4
Shane
Shane's Avatar
close up of pinion and crush sleeve
Old 09-15-2003, 09:33 AM   #5
Erl
Erl's Avatar
Are these for a Dana 60? If they will fit my GMC 3/4 4x4, I will take them. I currently have the 4:56 ratio, and believe the 3:73 uses the same carrier.
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 09-15-2003, 01:35 PM   #6
Shane
Shane's Avatar
These are for the Coporate 12 bolt style rear-end.
Someone also asked if this gear set is for a 3 Series or a 4 Series carrier ... how do I tell?
Old 09-15-2003, 01:55 PM   #7
CUSTOM/10
CUSTOM/10's Avatar
3.73 gears
3.73 gears and higher go on a 4 series carrier.
CUSTOM/10 is offline   Reply With Quote
Old 09-15-2003, 05:31 PM   #8
mocwon
Keep On Truckin'
mocwon's Avatar
3.73 gears will also fit series 3 carrier if they are the thick gears.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 09-16-2003, 08:55 AM   #9
CUSTOM/10
CUSTOM/10's Avatar
3.37 Thick & Thin
I wasn't aware that they made a Thick & Thin set of gears !!!!!
Was this from GM or was this difference an after market solusion to put different gears on other carriers.
Old 09-16-2003, 10:24 PM   #10
mocwon
Keep On Truckin'
mocwon's Avatar
3.42 and numerically larger GM gears are for the series 4 carrier. Lower numbers than 3.42 are for the series 3 carrier. However, gears are made for a series 3 carrier that are 3.42 and numerically larger. They are thicker to compensate for the difference in size of the carrier. I have never tried to find GM gears since Richmond, Precision and others make these gears for a heck of a lot less monsy and they are just as good or better than GM gears.
Just Passin' Thru
Old 09-30-2003, 02:44 PM   #11
72skytop
72skytop's Avatar
Gears
I have a 1971 Chevrolet half ton, series 10 pickup with the originally installed since brand new 3.08 posi rear end. Does anybody know if these gears will work? And what is the easiest way to find the correct speedometer gear for the 400 trans?
Thanks.
Kevin Korff
72skytop is offline   Reply With Quote
Old 10-01-2003, 05:42 PM   #12
Vince M
Vince M's Avatar
72skytop,
You'll have to change the carrier if you want to use these gears. As stated you would need the 4 series carrier. You currently have a 3 series if you have the 3.07 rear. Hope this helps..
Shane is the set still for sale or is it spoken for..?
Thanks,
Vince
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 10-01-2003, 06:33 PM   #13
Shane
Shane's Avatar
The set of gears is still for sale. PM or email me if interested. The email notification is not working when someone replies ...
Old 10-01-2003, 09:48 PM   #14
72skytop
72skytop's Avatar
Gears
Thanks for the information Vince. I read through all the previous posts on this and I could not come to the conclusion.
I guess I'll just keep cruisin' with the 3.08's....yuk. I want to do a burnout! Can't with these gears. 402 big block dog.....
