03-11-2012, 10:22 PM | #1 |
Help id some spots on a 1991 350 engine
Hi Guys,
I need some more help. I didn't take this engine apart and my manual is lacking a little. I have a port on each side of the engine that I would like to check out what they are for sure. A small one on the drivers side which I think was just plugged and one one the passenger side that I am not sure what it is. What do you think? |
03-11-2012, 10:54 PM | #2 |
Re: Help id some spots on a 1991 350 engine
If memory serves, drivers side is a plug that goes into the coolant passage but was also used for Knock sensor in later years, put in a plug, or drain cock to allow full draining of cooling system. Passenger side is coolant passage also, usually has pipe plug in it.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
03-11-2012, 11:46 PM | #3 |
yes, what rooster said. except i will add the one in the cylinder head is usually for a coolant temp sensor, but on the driver side. pass side can be plugged. should be a standard pipe plug.
03-12-2012, 05:33 PM | #4 |
Thanks guys, the temp sensory on this engine is up on top right by the thermostat, so I will just plug them both and move on I appreciate it.
03-12-2012, 06:48 PM | #5 |
here, just not logged in
The temp sensor on the top by the thermostat, is for the ECU. The hole on the driver side head is for, a temp sensor for the gauge. The one on the passenger side gets plugged.
03-12-2012, 07:36 PM | #6 |
That's why I love this board, Thanks. I will check into a new switch and see if I can hook it up to the 63 gauge.
Rick |
