Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Product Reviews
Old 04-26-2011, 02:27 PM   #51
Dano69c10
Dano69c10's Avatar
Re: GMC paul door seals are great!
subscribed
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 04-30-2011, 10:29 PM   #52
Lemield
Lemield's Avatar
Received mine yesterday....FAST shipping and these things are AMAZING!!!!
I am really sorry I waited so long to get these seals! They are easy to install and they seal great!
Thanks GMC Paul...you are the man!!!!
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 09-24-2011, 10:56 AM   #53
litew8
litew8's Avatar
Looks great. I know it hasn't been very long since most had installed, just curious if any have actually been in the rain since. Paul, if I were to purchase the 71' cab kit, could you tell me what is not included? Thanks
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 09-25-2011, 07:09 PM   #54
skoolbusyeller72
skoolbusyeller72's Avatar
I finished the interior in my truck today ,glued in new seals and the doors are hard as hell to close sooooooo i just ordered a set and the new glue in ones will hit the trash as soon as the push on set gets here ...
1972 Custom 10 LWB
1973 V8 Vega wagon
1925 Model T Wrecker
1913 Model T Speedster
http://s181.photobucket.com/albums/x...07/72skoolbus/
skoolbusyeller72 is offline   Reply With Quote
Old 09-29-2011, 02:36 AM   #55
litew8
litew8's Avatar
anyone?
Old 01-27-2012, 11:14 AM   #56
aventur1
aventur1's Avatar
Just ordered a set this morning...can't wait to install them! Thanks GMC Paul
Recieved my door seals and installed them, they went on great, the only problem that I would like to mention is on a tight corner while pushing them on to fit tight the metal popped through the rubber, small area but still exposed the internal metal. Other than that they are great. Mines a weekly driver, so all is good.
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline   Reply With Quote
Old 02-22-2012, 11:10 AM   #57
GMCPaul
Originally Posted by lakeroadster View Post
Paul,
Are the push on style seals available for 63-66's? I didn't see them online.
Thanks,
John
John AKA-lakeroadster I have some new door seals arriving in about 2 weeks I'd like you to test fit for me on your 66 and give me a review so if you could please email me your address as soon as they arrive I'll ship them to you. Email me at
robbinspd1199@yahoo.com
litew8 If you read the description of the cab rubber kit on our web site page it tells you every part that is included in the kit. If you do not see it in the description then its not included.
the following is that list
Includes
standard 8 piece door window seal kit,
vent window rubber kit,
door opening weather strip kit,
windshield gasket ( Deluxe or Standard),
Rear window gasket ( Deluxe or Standard) Specify Standard or Deluxe in Cart for 67-72 Large back window, 67 Small back window kit comes as standard or deluxe windshield gasket and standard rear window gasket specify in cart. You can optionally upgrade the door opening weatherstrip in the cart from our original style glue on version to our new and improved modern style that pushes on and requires no glue to install. Every Piece in this entire kit is backed with a lifetime warranty.
You'll find the cab rubber kit at this link
http://www.gmcpauls.com/Pickup.htm
Its the 1st item listed on that page.
Where as if you only want the Push-On door seals they are on the same page and are the 9th item listed on that page.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 02-22-2012, 03:27 PM   #58
litew8
litew8's Avatar
Thank you for the reply. I no longer need the door seals, so a kit isn't going to work.
I have a "Custom Deluxe", here's what I'm looking at now:
8 Piece Door Window Seal Kit For Custom & CST Trucks 280037
Includes inner felts with Chrome Bead, outer rubber seal, Division Bar Felt,&Door Glass Channel Run For Both Doors Used On CST & Custom Pickup, Suburban & Panel. LIFETIME WARRANTY.
$69.95
67-72 Division Bar Felt 360342
1967-72 Door division bar felt runs down back side of vent window bar from top at door upper frame to bottom inside door. For truck, Blazer, Jimmy, Suburban, Panel.
$12.00
67-72 Glass Run Channel 360346
1967-72 Door glass run channel, extends from inside door bottom at back of window up the rear glass run area and across top of door upper frame and ends at division bar. For Truck, Suburban & Panel.
$10.95
- Questions -
1) Are all rubber products manufactured by Precision?
2) For the 8 piece above (280037), it says "outer rubber seal", but the 4 piece anti-rattle kit (371090) says "2-outer rubber seals with chrome top bead" is included. Is there a difference for Custom Deluxe models, and why wouldn't the 8 piece kit contain outer rubber seals with "chrome top bead"?
4 Piece Custom & CST Door Window Anti-Rattle Kit 371090
For 1967-72 Truck, Blazer, Jimmy, Suburban&Panel. Includes 2-inner felts with chrome top bead, 2-outer rubber seals with chrome top bead, at bottom of window inside and out, does both doors. LIFETIME WARRANTY.
$39.95
Old 02-22-2012, 03:56 PM   #59
GMCPaul
$69.95
$12.00
$10.95
- Questions -
$39.95
All the rubber is supplied by Precision in this kit. The part # 280037 do have a chrome top bead attached to the 2-outer rubber scrappers and the 2-inner felts in this kit. Its just not in that description and I'll see about getting it added. The division bar felts do not have chrome beads. The division bar felt was installed at GM assembly plant then they crimped a chrome bead onto the rear edge of the vent window assemblies division bar surrounding metal inside & out. When they did this they often trapped a portion of the division bar felt under the edge of this chrome bead. So when removing the division bar felt to replace it run a razor blade along the edge of the chrome bead on the felt side of it this will cut any felt trapped allowing you to remove the division bar felt liner for replacement.
The part # 280037 includes 2 division bar felts and 2 glass run channels so if you only have the 1 truck there is no need to add the part #'s 360342 division bar felt or Part# 360346 glass run channel.
we use a Part # 371090 + 2- Part # 360342 & 2 part # 360343 to make our Part # 280037 kit.
To be sure your questions get answered quickly about any of our products you can contact us direct by emailing us at
as I don't always see every post here. Thanks for your interest!!
Paul @ GMCPauls
Old 02-22-2012, 04:21 PM   #60
aventur1
aventur1's Avatar
I bought these kits, liked all of it and fit was good. The only thing I did was cut my outside window seal to short, I did not consider going past the wing division bar another 1/4 inch to seal that little area.
A Shorter Step
Old 02-22-2012, 08:45 PM   #61
litew8
litew8's Avatar
Thank you for taking the time out of your busy schedule to answer a few questions! Really appreciate it! I know about the felt being trapped beneath the chrome on the division bar! I just finished sandblasting mine and noticed how some got trapped in that seam. The blaster cleaned it up good for me. Once I get organized, I'm going to buy from GMC Paul! Thanks again!
Paul @ GMCPauls
Old 03-12-2012, 10:25 PM   #62
jtp67-72
jtp67-72's Avatar
Got mine today--won't install for while but Paul my question is in the sharp corner of upper front --is there a trick to install in that area-no prebend in these so I was just curious---Shipping was super fast and where were these on my last 20 trucks???? lol.....thanx again.......jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 03-12-2012, 10:54 PM   #63
aventur1
aventur1's Avatar
jtp67-72
I would say just go slow and make sure it's tight push hard down to set as you go around that part keep the loose end pushing towards the part your pressing in the slot. The edges will seem so curl up as you go around corner so I used a very small screw driver to pull the lip up over the edge. Kinda hard to explain and the small loop wire inside the edgeing will tend to poke through, I just used the scew driver to lift edge and the wire will go back into the seal. You can use maybe stiff plastic so not to damage paint. It will be a little kinked at the 45 degree but as you shut the door it smooths out.
When you get to the end I cut it a little long then cut the bottom and used the extra rubber on top to tuck into where you began.
A Shorter Step
Old 03-12-2012, 11:02 PM   #64
jtp67-72
jtp67-72's Avatar
Thanx--figured someone had it figured out!.......jim
Old 03-12-2012, 11:14 PM   #65
aventur1
aventur1's Avatar
My doors are hard to shut but are getting better every time, been in about a month.
A Shorter Step
Old 03-19-2012, 12:57 PM   #66
MisterC
MisterC's Avatar
I'd love to get a set of the "push-in" style for my '66 if you get those test fit and are happy with them.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 06-16-2012, 07:12 AM   #67
GMCPaul
aventure1 check the ends of the door seal where they meet under the door seal plate and make sure if they are touching that you cut a 45 degree angle on either end, if they touch and no 45 degree cut is made on either end it makes it more diificult for the air in the bulbous portion of seal to escape which will cause the doors to close slightly harder than is required. This is recommend in the factory service manual per GM.
GMCPaul
Old 06-18-2012, 07:40 PM   #68
MisterC
MisterC's Avatar
Hey GMCPaul. Any progress on the "push on" style door seals for the 60-66?
Old 06-19-2012, 07:15 AM   #69
GMCPaul
I've tried Every profile of push-on weatherstrip thats currently produced and the version we sell for the 67-72 had the best fit on the 60-66 trucks but in my opinion they required slightly more effort than I felt should be needed to close the door, altough in my opinion the stock 60-66 seals do also require the same or nearly the same amount of pressure to close the door. So I was not able to come up with any for the 60-66 trucks thats perfect for them I'm sorry to say. We've had several 60-66 owners purchase the 67-72 push on door seal and they were happy with them but we will not be marketing them as a product for the 60-66 trucks.
Sorry I didn't have positive news for you.
GMCPaul
Old 06-21-2012, 02:05 AM   #70
MisterC
MisterC's Avatar
No apology necessary. I appreciate the detailed response. Based on the praise they've received from other members, I may just try them on my 66 none the less.
Thank you very much!
Old 07-24-2012, 03:26 PM   #71
Lemield
Lemield's Avatar
Just put another set on my K20....great product!
Larry
Old 08-24-2012, 11:15 AM   #72
robber grin
Question Re: GMC paul door seals are great!
GMCPaul
Hiya Paul - Am I understanding correnctly that you have 60-63 EARLY cab folks that have tried these with success???
If so - My 62 C10 will have to have a set for sure.
Thanks bob
robber grin is offline   Reply With Quote
Old 08-30-2012, 06:11 PM   #73
CC69Rat
CC69Rat's Avatar
70 GMC here, push on type door seals. In 15yrs of restoring trucks and cars, these are top notch fellas. .. buy em. I'm confident to say they're if not the best out there, they're really close. (top two) They will be going on my 68 too.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 08-30-2012, 08:58 PM   #74
jtp67-72
jtp67-72's Avatar
^^^^amen.......jim
Old 12-01-2012, 12:23 AM   #75
Chvy2NV
I'll be placing an order for my 67 real soon.. Paul could you do the \/ cut prior to shipping them out ?
Chvy2NV is offline   Reply With Quote
