Old 03-12-2012, 11:50 PM   #1
shawno72
C/10 junkie
shawno72's Avatar
I6 zbar in a V8??
I am wanting to know if my manual trans z bar and linkage from my 292 will fit on the 327 I'm going to install or do I need to get a v8 set up. Any help would be greatly appreciated
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-12-2012, 11:58 PM   #2
mooneyes
mooneyes's Avatar
Re: I6 zbar in a V8??
...the 6 cylinder z-bar is to wide and the clutch rod is different to...you can do some fabbing to make them work with some cutting and welding if you can't find any...
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 03-13-2012, 12:03 AM   #3
shawno72
C/10 junkie
shawno72's Avatar
Welding and cutting I can do. Just wanted to know up front what I need to make the swap go smoothly. Thank you.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-13-2012, 12:07 AM   #4
shawno72
C/10 junkie
shawno72's Avatar
How about the piece that bolts onto the block?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-13-2012, 12:24 AM   #5
mooneyes
mooneyes's Avatar
..don't remember for sure which one I used ...but I can get you a measurement on the v8 z-bar this weekend if that would help.
78 caprice project
Old 03-13-2012, 12:29 AM   #6
mooneyes
mooneyes's Avatar
...this is the bracket I had to build for mine..gm was nice enough to do away with the second bolt hole when they went to passenger side dipstick...
78 caprice project
Old 03-13-2012, 04:17 AM   #7
sharpmark
this may help if you have the right holes in the block-look for my replies to this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=500246
if your block doesn't have the holes,mooneyes bracket above looks easy enough to make.
good luck
1969 stepside-305/4spd/12 bolt posi
http://67-72chevytrucks.com/vboard/s...d.php?t=477157
1968 pontiac lemans convertible-350/pwrglde/10 bolt
1934 oldsmobile sedan-350/350/12 bolt posi
1930 model a pickup-350/350/jag ind
1928 model a roadster-283/350/9"
sharpmark is offline   Reply With Quote
Old 03-13-2012, 08:47 AM   #8
shawno72
C/10 junkie
shawno72's Avatar
Cool thanks guys. I'll have to look at the side of my block and see if the holes are there.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-13-2012, 09:31 AM   #9
socalkevin68
socalkevin68's Avatar
the z bar from my 6292 bolted right up to my 350 no problem...
socalkevin68 is offline   Reply With Quote
Old 03-13-2012, 10:17 AM   #10
shawno72
C/10 junkie
shawno72's Avatar
Thanks Kevin thats what I was wanting to hear.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
