03-13-2012, 01:43 AM | #26 |
Re: Recessed Autometer Gauge build
I like this one , i'm in. I'll be watching for sure.
Life is to short to drive anything else |
03-13-2012, 06:47 PM | #27 |
A very nice clean setup, nice update over stock. The price of the gauges are not bad either.
03-18-2012, 12:56 AM | #28 |
yeller
Small update.
Cluster housing modified...cut so that the new gauges would fit, yet provide the necessary upper/middle mounting points, lower gear shift provision, and factory turn signal usage. I am not sure that the lower left section can be retained due to small gauge size...if not, the owner will have to cut off the piece to the left of the gear selector and attach it to the metal dash with a support bracket. While this piece will never be seen once the gauges are in, I made the cuts as straight as possible, and sanded everything smooth. It is still dirty in the pics, but it has been cleaned and ready for installation.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 03-18-2012 at 01:17 AM. |
03-18-2012, 01:02 AM | #29 |
yeller
Here you can see a spare lens I had laying around that I cut the gear shft indicator portion off of that will be epoxied to the backside of the dash bezel itself. It too has been sanded smooth, even though it will never be seen.
Bottom pic is of a 5" ring that was removed from the speedometer. I simply cut a slit in it, which gave me enough room to pry the rest of it off carefully with a pliers. I did have an accident on one of the smaller gauges, which required me to make a phone call to Autometer for a replacement lens.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
03-18-2012, 03:23 PM | #30 |
Nice!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
03-18-2012, 07:07 PM | #31 |
looks great!
04-10-2012, 11:25 PM | #32 |
yeller
OK, cluster is DONE!
However, I don't have final pics yet as I need to take it all apart, document, clean and re-assemble. I will have pics up tomorrow evening. Until then, here are some in-progress pics. Sorry for the quality, bought a new DSLR and am trying to learn how to use it.
04-10-2012, 11:27 PM | #33 |
yeller
Some more
04-10-2012, 11:50 PM | #34 |
wow
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
04-11-2012, 01:00 AM | #35 |
More please
04-11-2012, 11:22 PM | #36 |
yeller
Lastof the pics
04-11-2012, 11:24 PM | #37 |
yeller
Bill, I'll get this packaged up and out by the end of the week. Thanks, hope you like!
04-12-2012, 01:54 AM | #38 |
Just here to tinker
Amazing work! Just beautiful.
There is one thing I'm just not ready to embrace yet though. . . Why do so many people want 160 MPH speedos and 10k tachs when these trucks will rarely go faster than 120 and most of these small blocks will never rev higher than 6k? Just a thought.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
04-12-2012, 02:13 AM | #39 |
WOW! Very nice work
04-12-2012, 03:32 AM | #40 |
very nice
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
04-12-2012, 06:50 AM | #41 | |
yeller
04-12-2012, 06:50 AM | #42 |
First Class Job very nice.
04-12-2012, 07:00 AM | #43 |
Very nice job Jeff , Looks great !
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237 |
04-12-2012, 08:15 AM | #44 |
78K & 79C Jimmys
looks awesome,great face choice
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-12-2012, 08:59 AM | #45 |
WOW!!!! Yeah, If i had the money i would get this done too!!!
04-12-2012, 12:46 PM | #46 | |
optomistic ah-so
That is, one methodology dictates that you want to position the gauges so that, when everything is working right, all the needles are pointing straight upwards. In many race applications you'll see gauges rotated in their positions so that the shift point or redline on the tach is straight up, or the temp gauge is set for 180/195/220 is straight up or whatever the driver needs to see because they can't actually take the time to read the actual numbers. Aftermarket gauges were originally made to satisfy this need (Although the same companies also made gauges for military and commercial markets) and then they modified items for the street rod and similar customers. Check out your water temp or fuel gauge. They are not necessarily marked in a manner accurate to their function at the ends, but usually more accurate at the middle of their sweeps.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
05-13-2012, 10:29 AM | #47 |
PERECT. thats how this bezel came out. i contacted Jeff about his brackets a couple months ago. he didnt have a set to work with the carbon fiber gauges. our solution was to send the bezel and the gauges to him and have the brackets made. while he had both he would put them together. his quality and workmanship was second to none. he took time not to scratch the bezel, made sure everything was square, and when it was done shipped and insured the package. im impressed. i joined this site looking for information and help with my restoration i started three years ago. i have met many great people including Jeff. if anyone is looking to have their gauges done the same way i would not hesitate to recomend him. he is very passionate about his work and it shows. -Bill
05-13-2012, 11:00 AM | #48 |
yeller
Thanks Bill for the feedback. It was fun working on your cluster assembly, now I can't wait to see it installed in your truck.
I'll give you a ring tonight, to fill you in on a couple tips prior to install.
05-13-2012, 03:46 PM | #49 |
Great work,I have been looking at the Dakota Digital gauges since they came out. This is a good alternativ.
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
05-13-2012, 09:24 PM | #50 |
VERY nice!!! pm'd
84 c10 stepper: mildly built 355ci, 700r4 w shift kit and stall converter, .373's w an auburn posi unit. GO HOKIES!! |
