need help with engine #s
I have a 71 c10 lwb fleetside p/u it should have a 350 in it but the engine serial numbers do not match the vin # and I have not been able to find any help with the stamped numbers from the pad on the right side front of the block the numbers are V08210KD would like to know what I got thanks
#2 | |
![]() Join Date: May 2010
Re: need help with engine #s
http://www.nastyz28.com/decode.php
Mac 1970 GMC SWB 1971 Chevy C-20 Longbed Driving Miss Maybel: http://1970gmctruck.wordpress.com/ My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=513475 |
#3 | |
Stamping code V0821OKD
V= Flint, Michigan engine plant 08= August 21= August 21 build date OKD is the suffix code but is not listed. Can you recheck last three letters? Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
checked #s again and it looks like a vo8210kd but might be vo821ckd also got #s from back of block drivers side 3970010
#6 | |
a CKD is a 1977 350 a/t, high altitude 180hp out of a Vette
checked #s again might be ckd also got #s from back of block drivers side 3970010
Again it shows a 180hp out of a vette
#9 | |
CKD 1972 350 175 4bbl tur hydro trans CKD 1973 350 200 4bbl tur hydro, Calif CKD 1974 350 160 4bbl T350 NB2 CKD 1977 350 180 4bbl a/t, high altitude I don't know what "NB2" means on the third listing. It would help narrow the possibilities if you could get the casting number of the block. It's almost impossible to do with the engine in the truck. The numbers are on back of the block on the driver's side, partially hidden by the distributor. If you lay across the engine and shine a flashlight down behind the intake manifold you should see them. You will probably have to remove some greasy crud unless the engine has been freshly built or painted. The casting numbers will read something like 3970010, 3970041, etc. There are dozens and dozens of castings, and all will help you solve the mystery. NoNeck
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
Sorry about missing the casting number. As I was composing my answer, you were adding info. The 3970010 is a nice block (High Nickel content).
NoNeck
thanks for everyones help now I know its a 350 but can anyone tell me where to look for more info on the block to help ID its HP or what vehcile it might have been installed
A&P, Get the date code off the block. It's back by the casting number, only on the other side.
CHEVY/GMC VIN DECODERS |
![]() Join Date: Feb 2004
3970010
327 68-69 corvette, camaro, other hi perf 350 68-76 Truck and hi performance 4bolt but could have been 2 bolt |
fouind date code H 18 3 also # from front pad below head vo821ckd and 14c108751
#15 |
A&P Here are all the possibilities. In order to narrow it down to one we must know the vin# of the original vehicle and what car it was.. Your engine was cast in Aug of 73 and installed in a 1974 vehicle.
CKD camaro 74 350 160hp 350trans vin code L CKD camaro 74 350 185hp 350trans vin code K CKD chevelle 74 350 160hp 350trans vin code L CKD impala 74 350 160hp 350trans vin code L CKD nova 74 350 185hp 350trans vin code K
#16 |
you got a 74 camaro 350 built in aug in flint put in the car in sept in lansing and delivered to cali. now im guessing this is a 185 hp motor cause it has the nb2 which is cali emissions, but you got a 10 block and thats the good news. I would pull a valve cover and check your heads, if it is a smog motor im guessing it might have the 1.94 valve 76cc heads but not sure. but you do got the good block so if you want some more power you might just need to find some heads. but thats what i got out of the numbers
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
#17 |
pulled valve covers and head #s are 333882 I also have a set of sbc heads #3986339x I think they have smaller cumbustion chambers, would they help this engine.
#18 |
the heads that are on it are 76cc 1.94's i think the other set you have are the same chamber size maybe 74cc but the valve size should be smaller maybe 1.74.......so I wouldnt put those on. the 1.94 76cc heads arnt bad heads but if you want to overhaul your motor someday you might want to upgrade, its all about the mighty dollar and how much you want to dump into it. in the meen time if you come across a good deal on a set of heads buy them.
