Old 03-15-2012, 01:39 PM   #1
jughead12
Question newer rear end and trans?
will a rear end out of a 91 work in a 73-87?and will a 4l60 work in one?
jughead12 is offline   Reply With Quote
Old 03-15-2012, 10:22 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: newer rear end and trans?
Yes the rear axle will work but the spring pads and shock tabs will have to be cut off and re-welded in the correct locations. I just put the rear axle from an 04 under my 73.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 03-16-2012, 02:57 AM   #3
andrewmp6
The 4l60 will take a controller for it to shift and you will have to move the trans crossmember.
Old 03-25-2012, 05:03 PM   #4
Goats86
Hey Ghetto, tell me about your wheel selection after the 04 rear end swap. I would like to do the same using a late model disc brake rear but just have not figured out how to match the front of my 2 wd 86 1/2 ton. Pics maybe? Thanks
Goats86 is offline   Reply With Quote
