cab dimension HELP
I need to know what is the measure from lip to lip
I stole this picture from ( BucksSS ) Thanks
Pancho 69 c/10 step side 454/400 with 3.07 |
Active Member
![]() Join Date: Jul 2007
Re: cab dimension HELP
My 68 GMC shows 35¼ inches. Should be the same as others but I have a stripped out cab from my old 69 Chevy in another location and can get that later this week if someone else doesn't have a confirmation for you.
![]() Join Date: Apr 2007
That sounds right. I took that measurment before I cut the floor and rocker out of my cab. I will double check but I think thats good.I'll repost if I find something diffrent.
In my cab driver side have 34 2/8 [1/4] and pass side 34 3/8 is a big gap in my pass side. I think that is the problem.
Here are some pictures from my can and I welded all corners before take off the whole floor. Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
Yea I went and measured my cab again and it was really 34 and a scant 1/4. Like I said before I measured it before I cut anything out and this cab was pretty tight when I got it.
Thanks guys for your support.
Active Member
Just for the heck of it I measured more towards the bottom from where I checked this morning and it's 34 5/8 inch. So I guess the measurement is going to differ slightly depending on where you measure.
