What tire size? Stock ride height.
Which tire size do you think would fit better on a stock ride height 68 Stepside?
. LT265/75R16 or LT285/75R16 I plan on buying Mickey Thompson Classic II 16x8 wheels and Mickey Thompson Baja ATZ Radial tires from Performance Plus online so I want to make sure I'm getting the size right before I order. Thank You Troy Posted via Mobile Device |
Re: What tire size? Stock ride height.
If you have a 1/2 ton 2wd Those are both pretty big. The front turning clearance of the lower front edge of the wheel well may be an issue.
If it is a 4wd I am not sure. I have 285-75/16 on the back of my 3/4 ton and they are 33 in. tall. |
#3 | |
Thanks Again Troy Posted via Mobile Device |
The 265-75/16 sounds like better choice as long as you have room in the front.
Maybe someone who is running those can shed some light as to wether they have plenty of turning clearance. |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
The 265/75's ae 31.62 inches high and the 285's are 32.82 inches high. If you know what size tire was originally on the truck you can calulate the height of those and see how high the new tires are in comparison. If you are not sure how to calculate just post the size on here and I'll do it for you.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#6 | |
Front - 7-17.5-6 Rear - 8-17.5-8D Thank You Troy Posted via Mobile Device |
#7 | |
7 17.5 -6 7 Sidewall Height 17.5 Rim Diameter 6 6 Ply Tire So you have 7 x 2= 14 + 17.5 = 31.5 inch tire on Front 8 17.5-8D 8 Sidewall Height 17.5 Rim Diameter 8D 8 Ply Tire with Load range D rating Again 8 x 2= 16 +17.5 = 33.5 inch Tire on Rear Hope this helps. It looks like the 285's would be to high for the front.
