Old 03-16-2012, 07:08 PM   #1
ivorton74
ivorton74's Avatar
installin a starter button..need some help.
I have a starter button that im tryin to hook up in my 74. I bought it off ebay. I just got done puttin the button itself in the dash so now I just have to wire it up. There is a wire that hooks up from the button to a relay box. Then I have to hook up some wires to the box to the ignition. There are 3 wires...black is for ground...then theres a blue and a red wire that supposedly goes to terminal 15 behind the ignition switch and im supposed to run another wire to terminal 50. Those are according to the instructions. So anyone has an idea where these terminals are on our trucks. Any help is appreciated. thanks.
ivorton74 is offline   Reply With Quote
Old 03-16-2012, 07:16 PM   #2
Goldfinger
Goldfinger's Avatar
Re: installin a starter button..need some help.
I did it on my f***. I'd puledl them off the ign switch mounted under the column behind the dash. find a good thick power wire and the starter wire which you may need a diagram for.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 03-17-2012, 12:44 PM   #3
ivorton74
ivorton74's Avatar
any other ideas?
Old 03-18-2012, 12:41 PM   #4
ivorton74
ivorton74's Avatar
ok so i figured out where these wires are supposed to go. there are actually 4 wires...one goes to ground, a red wire goes to an accessory, one blue wire goes to the ignition wire and the other blue wire goes to a constant power source. any one know where the ignition wire is on our trucks?
Old 04-02-2012, 01:25 AM   #5
Square_78
Square_78's Avatar
In the steering column running up to the ignition switch. Just splice into those wires. Ignition wire will be powered while cranking( the starter). Acc wire will not have power while cranking. If you cant figure it out, take your truck to a good car audio shop and get them to install it. Wouldnt take more than a half hour for them to install the button and wire it up.
Square_78 is offline   Reply With Quote
Old 04-02-2012, 07:59 AM   #6
silvereagle07
silvereagle07's Avatar
Here is a link to Captkaos' site that may help.
http://forum.73-87chevytrucks.com/sm...o8pvdp0otslks0
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 04-02-2012, 09:14 AM   #7
chrismoore701
chrismoore701's Avatar
I thought all you would have to do is cut the wire that goes to the key that gets power when you crank, and run that one wire through the button. So if I read this right, there are more wires involved
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 04-02-2012, 10:52 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
button only engages the starter
truck needs to have power after you release it
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-02-2012, 05:37 PM   #9
vegas80step
vegas80step's Avatar
I used the auto lock kit.. with RF proximity.. thing is cool if your truck is running WELL..
Not cool part is I forgot about the Rf chip and left in it side and spent 20 minutes trying to figure out why my truck wouldn't start... lol...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 04-02-2012, 08:56 PM   #10
ivorton74
ivorton74's Avatar
wow i thought this thread was dead. anyway i already mounted the button on the dash by the headlight switch. just needs to be wired up. heres a pic of the button below. its a pivot starter button...
Old 04-02-2012, 09:49 PM   #11
ktm450
push buttons starts are sweet, read about some saying put one inline with the ignition wire from the key. its actually a good idea from a security stand point. i did this on my dads 70 cutlass. we put a momentary pushbutton in the glove box. so you turn the key all the way to start and nothing happens until u push the push button. this way if someone is gonna try and steal your car via collum smash or screwdriver nothing will happen. and usually they dont want to hang around long enough to figure out y. you can put a push button anywhere really, think im gonna put mine on my truck under the dash or something in that area.
if you want to do this to your truck its very simple, by yourself a simple momentary push button that will handle at least an amp or 2. locate the wire that comes off your ignition key. cut the wire, best to do it under the dash, connect one end to a lead on the pushbutton and the other lead to the other wire on the pushbutton, direction doesnt matter. and voila simply pushbutton start theft feature
ktm450 is offline   Reply With Quote
Old 04-03-2012, 10:37 AM   #12
chrismoore701
I am planning to do this on my 79. I am going to retrofit a push button into my cigarette lighter, it is going to be killer
Chris
Old 04-03-2012, 05:44 PM   #13
Square_78
Square_78's Avatar
I think i am going to go this to my truck. I am going to hide the started button somewhere on the dash. I want it to be more of a security feature. Put the key in and turn it to ON, then press the hidden button. Pretty cool.
