03-16-2012, 08:24 PM | #1 |
Active Member
tac wiring question
I would like to wire in my tac .I didnt see it on the wiring diagrams the are posted. Can some one tell me the ins and outs on wiring the tac.
67 short step 71 Custom |
03-16-2012, 08:28 PM | #2 |
Re: tac wiring question
DittoPosted via Mobile Device
'71 Chevy LWB all OG '86 Chevy LWB all OG It's all a matter of perception |
03-16-2012, 11:59 PM | #3 |
Same here lol
1969 Chevy c20(Miss Hackjob) |
03-17-2012, 10:16 AM | #4 |
Sierra Grande Club
IIRC it a single wire that runs through a specific hole in the fire wall.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
03-17-2012, 10:44 AM | #5 |
It's a two wire set up. One goes to a switched spot in the fuse panel and the other goes out to the distributor or coil depending on points or hei dist. I also ran a ground wire from the stud on the back to the dash. Try searching more, this is were I found how to wire mine. If nothing else you can buy a repro harness that's plug and plug from any of the big suppliers.
03-17-2012, 12:32 PM | #6 |
3 or 4 wire depending on your tachometer.
Probably a White/Red/Black/Green setup, on a lot of aftermarket tachs, the 4th being white, for a lighted tach, if applicable. Red -Switched 12v from panel/block/wherever. Black - Ground Green - Dist-Hei-Coil hook up. (Labled 'Tach' on most Hei's, not sure about a coil) White- Lights, splice in junction with dash lighting past the dimmer Not sure if you have a general aftermarket tach, someplace there's settings for 4,6,8 cyl that has to be adjusted.
68 GMC C2500 - 305 V6 - 4spd |
03-17-2012, 01:28 PM | #7 |
Good call, are you trying to wire in a factory tach or aftermarket tach?
03-17-2012, 01:45 PM | #8 |
Factory or aftermarket/points or HEI?
03-17-2012, 02:13 PM | #9 |
Factory points
03-17-2012, 02:22 PM | #10 |
Active Member
Thanks all. Got it wired and it working fine . Stock tac - HEI dizzy- two wires. one to fuze block ond to dist cap = perfect
03-17-2012, 03:14 PM | #11 |
Yup, should of been what I asked first.
