Old 03-18-2012, 09:10 AM   #1
jkrenzel
jkrenzel's Avatar
motor question??? not sure
Alright guys I bought a 66 C10 Stepside and it did not run at the time because the starter was fried. Well the guy that sold it to me said it had a 327 bored .40 over. So got it home and pulled the starter, and took it down discount auto and the guy looked up the pictures of the mouth of the starter and said to me are you sure it is a 327 .... I was like I think so. What happen then was, we had to go threw every starter in the system till we came across a 283 starter that matched up perfect. So I guess I have a 283 which does not bother me because it runs now. But is it possible that the motor is a 327 ???? I am pretty much clueless when it comes to knowing anything about motors but I can fix everything with ease. How can I find out more info n the motor?
thanks everyone
jkrenzel is offline   Reply With Quote
Old 03-18-2012, 09:35 AM   #2
64GMCHorsepower
Justified!
Re: motor question??? not sure
What numbers are on the block? That is an easy way to find out what you have.
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 03-18-2012, 10:54 AM   #3
61K10
61K10's Avatar
your starter bolt to the bell-housing or the block? early engs bolted to the B/H and yes your eng could be a 327. casting # on the back of the eng drivers side where B/H bolts to eng. also a pad on the front P/Side of eng should have some # & leters. post them up.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-18-2012, 04:34 PM   #4
jkrenzel
jkrenzel's Avatar
Great thanks let me look for those number can someone take a picture of where they are?
Old 03-18-2012, 04:57 PM   #5
suzq044
Resident Photoshop Nerd
suzq044's Avatar
^ hope that's clear enough? both numbers should be visible without taking apart the engine; we're just doing a rebuild.
PJ - 1966 C10 Panel --
Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline   Reply With Quote
Old 03-18-2012, 06:20 PM   #6
rideblue00
rideblue00's Avatar
Good info there suzq044. Pictures like that are so helpfull to those that are unsure where to look.
rideblue00 is offline   Reply With Quote
Old 03-18-2012, 09:50 PM   #7
jkrenzel
jkrenzel's Avatar
Wow thanks, hope I get a chance to look tomorrow and get you guys the info I need. Thanks again everyone, sorry I am slow when it comes to these things
Old 03-19-2012, 02:05 AM   #8
Captainfab
60-66 Nut
The 283, 307, 327 and 350 use the same starter in the '63-'72 trucks.
Old 03-19-2012, 08:32 PM   #9
jkrenzel
jkrenzel's Avatar
Good news got the motor number
Old 03-19-2012, 08:39 PM   #10
suzq044
suzq044's Avatar
3970014 - 350ci (1970-1976 year) - so it's neither a 283 nor a 327. sorry, i guess - the upside is easier to find parts for it.
3970814 doesn't exist, so that's a zero, not an eight, or any other number, according to our book there's nothing else that ends in 14.
I forgot to tell you; the 2nd set of numbers are under the alternator; pull that off / move it to the side.. and you should see it pretty clearly. it'll give you more info too. Like where it was manufactured & what type of car it came out of.
We're learning as we go tearing down & rebuilding this motor.
Old 03-19-2012, 09:09 PM   #11
jkrenzel
jkrenzel's Avatar
cool thanks everyone I guess its a done deal, ITS a 350 with a loud engine knock and a transmission that won't go into gear man.... I need to make friends that know how to work on this stuff. PS working in a Air force parking lot at base housing sucks!!!!!
Old 03-20-2012, 01:09 AM   #12
suzq044
suzq044's Avatar
Terry (my bf) knows alot of military-bases have a shop that can be used for a charge; a DIY type shop. If you don't already know where it is on your base, he said it should be listed under recreational or community services... hope that helps a bit.
Old 03-20-2012, 01:29 PM   #13
61K10
61K10's Avatar
if the eng has been rebuilt it could be a 327 if they used a 327 large journal crank and 327 pistons.
1961 chevy K10
Old 03-20-2012, 05:21 PM   #14
suzq044
suzq044's Avatar
Regardless, its not what the p/o said it was (bored out 327)..
If/when you tebuild the block you can pull the numbers off the cam, heads and intake for information. Our truck had a 283 2-barrel intake siliconed to death onto the 400 block. Ya never know what these trucks go thru over their relatively long lives.
Old 03-21-2012, 12:18 PM   #15
61K10
61K10's Avatar
didn't mean to step on anybody's toes---just saying it could be a 327 bored .040 over. built with a 350 block.
1961 chevy K10
Old 03-21-2012, 03:18 PM   #16
suzq044
suzq044's Avatar
AH gotcha.. i didn't catch the math there; my mistake lol
motor info
