#3701 |
Junior Member
Re: What did you do to your truck today!
Drove it to work after spending the last 6 months making it a short box. Woo Hoo! Alignment (Les Schwab) Friday and exhaust (Jeff @ Dan Fast) Saturday. OK I guess "I" didn't do that to it but I've done everything else!
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
#3702 |
A day late and $1 short...
@ Stomper - Awesome! Glad you get to enjoy it.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#3703 |
Nice job on the short box Stomper, well worth the effort for sure.
#3704 |
Couple of days behind here, took it out for a drive Sunday afternoon had a hole in the radiator so had to stop and give it a drink a couple times. Monday afternoon swapped out the bad radiator for a good one from one of my parts trucks. I love working on these trucks, half an hour from drain to refill! It was such a nice evening, my wife and I washed it today, got all the mud and mold scrubbed off. That 70 GMC bumper I installed that had been stored since 1970 shined up so nice! I didn't think to take a pic, but all the colors look much nicer now! LOL
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
#3705 |
Took steering wheel off and put new turn signal cancel on. Should have new black 3 spoke steering wheel here tomorrow, the Corvette style with Chevy bowtie horn button. Still waiting for seat from upholstery shop. Took red bowtie off front grill that th PO had painted red, striped the red paint off now have a chrome one.
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
#3706 |
Here is my progress today.Rubber floor down, glove compartment installed, instrument panel wired and installed. Man, I am loving this build.
I know I can! I know i can! 72 K20 Restoration |
#3707 |
wrwelton
Yep been doing all the same to mine...Looks good
#3708 |
Sheetmetal Psycho
Drove all over getting supplies for a friend. Go to leave and she won't start. horn works. Fuel pump comes on. Not even a click from the starter. Posting over on electrical to see what might be suspect. I'm guessing I burned a wire on the headers, but I guess maybe the starter switch could be the culprit.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
#3709 |
Picked up a 4l80e trans. Why do people never drain old oil from engine or trans before pulling them? I used a cherry picker to get it out. This sucker is heavy.
#3710 |
I installed the bulkhead fitting for my air conditioning lines in the firewall tonight. Of course the Aeroquip fittings I bought won't thread onto the bulkhead fitting, something is wrong with the threads. I wonder how Vintage Air will handle this little problem.
#3711 |
Collector of Projects
Instead of assembling my brakes, I pulled it further apart... Fixed the bad helicoil... and figured out I need some new seals and probably lower kinkpin caps...
#3712 |
Wait for the mail to turn up with my rebuilt power steering box , then promptly bolted it all back together ...time to bleed the system then I'm good to go ...another job out the way , next on the list is reinstall inner guards to keep the engine clean and shiny ....
69 C10 350/350 flat bed 51 stepside LT1 350/t700r 88 C4 Corvette targa 350/t700r 65 C15 longbed |
#3713 |
new wheels
#3714 |
#3715 |
Washed it and went for a mini-cruise. Installed the transmission shifter indicator, but think I have the wrong one since it sticks above about the housing.
![]() ![]() It ain't yours, if you didn't build it! |
#3716 |
finally installed the new weather molding around the doors and getting ready for some carpet.........
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
#3717 |
Covered my shifter handle with velour and a few extras.
Brad handshoe |
#3718 |
Painted my driver's side door. Only have the front clip, tail gate and rear wheel tubs left to paint.
#3719 |
I picked up my truck if that counts....
Posted via Mobile Device |
#3720 |
I found out last night I got the wrong plug wires from summit so i went to the parts store and got some MSD universals. That was the biggest pain in the ass until i discovered dish soap makes the boots slide much better.
#3721 |
My son just bought this little 69 shortwide last sat and yesterday he started installing his ECE 4.5/6 drop.
Will have finished pics later today.........and yes, there are jackstands under the frame.
1971 chevy c10 ECE 4.5/6 dropped 1970 suburban ECE 4/6 Dropped 45K original miles so far 1948 Ford Sedan 1941 Dodge COE 1932 ford roadster the rest are normal drivers |
#3722 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Replacing rust with sheet metal... Kinda burned out on the whole rust deal....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#3723 |
Cleaned out the truck and took the bed off. Now time for the lines, wiring, and fuel tank.
Always remember those that had your back Never forget those that turned it Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt, Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner |
#3724 |
![]() Join Date: Nov 2007
Got most of the way finished with my new rocker install.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
#3725 |
C/10 junkie
Finished reassembling my freshly rebuilt tranny.
![]() ![]() Posted via Mobile Device
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
