03-21-2012, 09:48 PM | #51 | ||
Just a Member
Re: Restored Auto Tilt Column
All of these tilts will fit in any 1967-1972 truck. The difference in 1967 columns and some 68's is they have one complete longer steering shaft. The 69-72 have the collapsible intermediate shafts which attach to the the steering gear box. I believe it was a safety standard upgrade so the steering column would have some give upon a wreck or front end collision.
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
03-21-2012, 10:43 PM | #52 |
Heavy Metal, Why is your account "SUSPENDED"??? Never seen that in this forum.
03-23-2012, 11:16 AM | #53 | ||
I have installed a van tilt without moving the NSS. What am I missing? It worked for me. Maybe it's good to not know better? I went to put the one I had installed in a truck for 15 years and was laying around a few years. I was surprised,after reading about them on this website,that the NSS was still in the original van position knowing it fit perfectly fine before. I had bought the column completely restored from Cheyenne Super Man as a truck tilt before I knew better. I installed it and used it before I knew better,too. But,I put it right in another truck just fine.
03-23-2012, 11:55 AM | #54 |
Actually it was no tilts until 1970, but anyway, the only way I could MAYBE see a van NSS working in the van location is if the column was shoved all the way toward the dash panel with the shift collar touching the dash rubber seal. If you put the column where it belongs, with the little tab on the brake pedal mount, in the correct slot in the column, the NSS wont fit.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-23-2012, 12:17 PM | #55 |
is there a side by side comparrison/picture of this somewhere?
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
03-23-2012, 05:34 PM | #56 |
Here you go!
03-23-2012, 08:23 PM | #57 | |
Always on the hunt...
Here are a few more labeled side by comparison shots to check out, both of the pictured van tilts have had the N/S-B/U switch moved/modded to the correct truck postion. |
03-23-2012, 08:49 PM | #58 |
Which is the area that has to be "collapsed" ? Thanks for the info. Im loving this thread.
Posted via Mobile Device |
03-23-2012, 08:54 PM | #59 |
03-23-2012, 09:56 PM | #60 |
67-72 parts collector,…
How is everyone making the van "splined shaft" shorter,... to match the length of the oem truck shaft?
Cut and weld?
03-23-2012, 10:15 PM | #61 |
Here are a couple of pictures showing the intermediate shaft and where it needs to be collapsed 2-3/8" for use w/van tilt. Mel
03-23-2012, 10:35 PM | #62 |
Just a Member
AHHHHHHHHHHHHHHHH. A breath of fresh air... Can you smell it??? Hey I appreciate all the tutorials and such they are really informative but this is not a general discussion forum nor thread. Nonetheless can we get back to my thread please? Thanks guys! Here is a link for anyone needing more info here is a throwback link.... which I already posted originally on the first page of this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=147927
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog Last edited by HeavyMetalChevy; 03-23-2012 at 11:03 PM. |
03-23-2012, 10:38 PM | #63 | |||
Just a Member
03-23-2012, 10:39 PM | #64 |
Just a Member
Yes you can do that or find an RV tilt which many have the same length steering shaft as a truck..
03-23-2012, 10:40 PM | #65 |
Although fairly common today with several of the column guys and most if not all of the restored GM "TRUCK TILT" columns listed in the big name parts catalogs, I am not a fan/believer of this cut and re-weld the lower inner shaft method. Dont get me wrong, the one's that are cut, welded and then collared over the joint with each end of the collar welded back to the inner shaft would be plenty strong if done correctly, but most I have seen are just but welded back together w/o a collar or sleeve. I feel if a guy wants the real mccoy "TRUCK TILT" and has paid the money for it, he should get what was paid for and not some cobbled together piece that could put someone's family in harms way if it failed. Mel
03-23-2012, 10:52 PM | #66 | |
03-23-2012, 11:04 PM | #67 |
Just a Member
now it does!!! I must have missed something copying it
03-26-2012, 09:40 PM | #68 |
I looked at my truck today, and don't see how it would even be possible with the column shoved all the way toward the dash, the brake pedal rod would hit it.
03-26-2012, 09:44 PM | #69 |
I agree with Mel. The best way to restore a van tilt to a truck tilt is to remove the shafts, shorten/cut and respline them.
04-12-2012, 11:32 PM | #70 |
Just a Member
ttt
04-26-2012, 12:28 AM | #71 |
Just a Member
ttt got about 6 of these to do
04-26-2012, 10:40 AM | #72 |
why not cut, shorten and reweld the shaft up high and not have to respline it. thats how gm did it. next time you have one apart look at the upper end of the shaft. it will have about a 2" area that has been turned and useally blued from heat. thats where the 2 pieces were welded together and then the weld turned down
04-26-2012, 12:01 PM | #73 | |
Just a Member
04-26-2012, 02:39 PM | #74 | |
04-26-2012, 03:05 PM | #75 |
how much pressure is put on the weld as you turn the wheel, even if you dont have power steering. it would have to be a really crappy weld to break under normal use of turning the wheel.
