Need help with wilwood master cylinder....
I purchased the Wilwood tandem master cylinder and proportional valve from summit. I was about to connect all of my break lines up this weekend and was reading up on wilwood master cylinder.... from my readings it looks as if I do NOT need the regular GM style proportional valve. I will need the adjustable valve only on my rear lines. Is that right?
So I should be able to tie the two front break lines directly into the master cylinder?.... then tie the two rear breaks directly into the master cylinder but install the adjustable pressure valve somewhere along the frame rails? I threw this together in photoshop.... does that look right?
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build Last edited by funkytechmonkey; 03-22-2012 at 12:48 PM. |
Re: Need help with wilwood master cylinder....
You've got it down! I'm running the exact same set up on my '71. Are you running a booster or going manual brakes?
Yep, that's it....
67-72 parts collector,…
![]() Join Date: Nov 2002
I plumbed one of these on the frame.
Adjustable, 2 front ports and 1 rear port, for brake lines,... and a brake light sender.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-22-2012 at 08:16 PM. |
#5 | |
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
#6 | |
Im assuming it doesnt matter placement due to the pressure in the lines, but didnt know if there was anything about the prop valve being at a lower point in the system than the calipers etc to watch out for |
GM Addicted
Keith what did you use to bend a flare all your lines that looks good. Also did you have to put some type on the back of valve so the know would not hit the frame?
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#8 | |
The 73-87 trucks had the factory prop valve mounted on the frame's radiator support crossmember. The issue comes when you mount the M/C lower than the calipers. (like the under floor "frame mounted" M/C that the street rod guys use)
#9 | |
There is a spacer behind the Prop valve. This made it easier to work the adjustment knob.
GM Addicted
cool man. what about flaring tool? have you ever used the eastwood flaring tool they have its like 200. very nice.
Flaring Tool
Sturgis, Michigan..... Not South Dakota. But, yeah, we are getting into the whole Bike Week thing here, also.
Haha... I just looked at sturgis. Didn't notice the state.
