Old 03-23-2012, 12:01 AM   #1
savatreatabvr
savatreatabvr's Avatar
Brush & Roller Paint Job?
Funds are tight so I've been pondering the idea of using a painters roller and brush to paint my truck! I know, never in a million years would I consider something like that but I came across a site that makes it look possible! What do you think?
Check it out!
http://rolledon.forummotion.com/f2-projects
savatreatabvr is offline   Reply With Quote
Old 03-23-2012, 12:19 AM   #2
Pop's C-10
Pop's C-10's Avatar
Re: Brush & Roller Paint Job?
Go for it..i bought a cheap spray gun jus so i can do mine with tha time permits..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 03-23-2012, 12:20 AM   #3
Squareforceone
Squareforceone's Avatar
Not this again..
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 03-23-2012, 12:29 AM   #4
Pop's C-10
Pop's C-10's Avatar
Originally Posted by Squareforceone View Post
Not this again..
Yes..this again & if you don't have anything helpfull for to OP..the lil red X in tha top right will assist you in leaving...thanks for playin..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 03-23-2012, 03:04 AM   #5
kylep
kylep's Avatar
i have heard of this and even seen a guy rattle can and get this close. I havent done it but i think anything is possible if you ve got the time to sand and buff. But i got to think it is a lot of sanding.
kylep is offline   Reply With Quote
Old 03-23-2012, 07:22 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
i didn't sleep at a holiday inn last night
but i did roll and brush my truck last year when some others were
it was suggested at the time to thin it out,quite a bit
this was my 4-5 th time rolling a paint job
aside from somebody keyed the drivers door,it still looks great
I used gloss tremclad
starts about here
http://67-72chevytrucks.com/vboard/s...=421767&page=7
and Kikkegek did his as well but he thinned it and it looks much smoother
http://67-72chevytrucks.com/vboard/s...=415333&page=3
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-23-2012, 08:33 AM   #7
D.FENS
I have seen cars with Rustoleum (or Tremclad) roller jobs that looked okay, but what happens if you decide to paint it for real later?
The solvents in most primer / sealers will wrinkle or lift uncatalyzed enamel.
D.FENS is offline   Reply With Quote
Old 03-23-2012, 10:06 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
you would have to strip it
the ones I've done, winter cars,camping, bush trucks
87 flat black bout 3 or 4 coats
bird pic bout 5-6 years later
John
Old 03-23-2012, 10:11 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
or fun
John
Old 03-23-2012, 10:20 AM   #10
TDS-MN
I did my truck this way last fall. Rolled on Rustoleum unthinned, because I wasn't really looking for it to self-level that much, my bodywork was already pretty rusty and rough. I sanded the really rusty spots, brushed on some rust converter, then a coat or rustoleum primer, then the paint direct out of the can. The finish has a small amount of 'texture' as I just left it as the roller, didn't try to smooth it after with the foam brush as some have done.
My truck is rusting away, and it's not going to survive long enough that I will ever be painting it with proper automotive paint. But this way I was able to hide a fair amount of the rust from view, and hopefully buy enough time until it will need to be retired.
I have some pics linked in the "Brown Trucks" thread of the end result. It has held up nicely agains the Minnesota winter, although this year that wasn't as sever as normal. But I really do want to hit it with some car poilsh or wax or something, didn't get a chance to do that last fall before the cold hit.
I was disappointed only in the actual color, on the can it looked to be a much better match for my original dark brown. it ended up MUCH lighter once it dried. But I really only wanted to get the truck to match color-wise, as I had fenders in primer, a door from a red truck, and a nasty tailgate from the salvage yard, it looked like a real mutt.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
Old 03-23-2012, 02:20 PM   #11
Corts60
Just here to tinker
Corts60's Avatar
May I suggest rattle can? I have gotten away with many a rattle can jobs. In fact, the roof of my pickup in the photos below is rattle canned. Two cans of home depot paint for $16 total, I think.
Old 03-23-2012, 03:30 PM   #12
kikkegek
kikkegek's Avatar
I did. Used Rustoleum and rolled it on. The red paint was just getting too bad...
before
after:
kikkegek is offline   Reply With Quote
Old 03-23-2012, 03:54 PM   #13
gGMC DOG
If the Rustoleum has cared you usually don't run in to that problem
gGMC DOG is offline   Reply With Quote
Old 03-24-2012, 12:04 AM   #14
bigcow94
Snowfighter
bigcow94's Avatar
i did this on a hood to see what all the fuss was about. yes if you ever want to put automotive paint you'll have to strip it all off. prep work is the key as it is with any paint job. and yes there's quite a bit of sanding involved. here's a couple of pictures of my rolled on paint job.
'72 Chevy suburban 2wd-sold
'05 chevy trailblazer
'02 Jeep Wrangler
'03 Ford Superduty crew cab 4x4
'84 chevy c30 crew cab dually
bigcow94 is offline   Reply With Quote
Old 03-24-2012, 02:15 PM   #15
gGMC DOG
well i did not have to strip it all off but it was on there over a year sanded it with 220 then 400 and paint
Old 03-24-2012, 07:00 PM   #16
kylep
kylep's Avatar
that looks really good!
