03-23-2012, 01:04 PM | #1 |
Rear leaf mount
Finally, I am down to a bare frame (will post pictures later). Now comes the fun part.
When I was pulling the passenger's side rear leaf spring I noticed the rear spring bowed outward. I assumed it was the shackle, however after really looking into it I saw the rear mount for the shackle is shot. The hole has been opened up and needs to be replaced. Is this a piece I can buy aftermarket or something I would need from a donor truck? Thanks. |
03-23-2012, 05:04 PM | #2 |
Hollister Road Co.
Re: Rear leaf mount
year model would be helpful and no they don't make them. You have to buy used.
03-25-2012, 06:49 PM | #3 |
Re: Rear leaf mount
Ah apologies. 1949 Chevy 3100
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
03-26-2012, 09:59 AM | #4 |
Re: Rear leaf mount
Here is an actual picture of mine. The circle is highlighting the part to the frame I am looking for.
03-26-2012, 10:54 AM | #5 |
Re: Rear leaf mount
wrong side of the country , but he has a frame off a 51
http://67-72chevytrucks.com/vboard/s...d.php?t=516081
Retired and too busy to work. |
03-26-2012, 10:58 AM | #6 | |
Re: Rear leaf mount
03-26-2012, 08:42 PM | #7 |
Re: Rear leaf mount
if your not worried about puttin the truck back origanal u could get the springs an mountin brackets from under a s10 an you will fix your prob. an you will ride alot better just my 2 cents worth
03-26-2012, 09:50 PM | #8 |
Re: Rear leaf mount
You can get a machine shop to fab a billet one. It doesn't look like it would be to much to make, maybe add bushings and a grease fitting.
That looks like it has done alot of work in its day. Good luck Steve |
03-26-2012, 10:26 PM | #9 |
Hollister Road Co.
Re: Rear leaf mount
Let me see if I have a perch laying around in good condition.
03-27-2012, 08:06 AM | #10 |
Re: Rear leaf mount
Thanks for the help guys.
@STEVE60: The truck was a farm truck from South Dakota for all its life. It had been beat on pretty bad. @DWCSR: Thanks Dave.
03-28-2012, 12:47 AM | #11 |
Re: Rear leaf mount
I got some perches let me know if you want them
Posted via Mobile Device |
03-28-2012, 12:53 AM | #12 |
Hollister Road Co.
Re: Rear leaf mount
04-27-2012, 07:48 AM | #13 |
Re: Rear leaf mount
I am still looking for these pieces if anyone is doing a frame swap. Appreciate it. T
04-27-2012, 09:31 AM | #14 |
Re: Rear leaf mount
I've still got the perches on my frame if you still need them send me a PM. I'll make sure they are good enough when I get home tonight. The frame is bare so it would only take a few minutes to get them off and they need to come off anyhow. They won't cost anything but what the priority mail fee is.
04-27-2012, 09:57 AM | #15 |
Re: Rear leaf mount
Sent you a PM @mr48chev. Thanks again.
04-27-2012, 01:12 PM | #16 |
Re: Rear leaf mount
Ahhh.. It's the rear you need. I thought it was the front for some reason. Mine are welded on but I could cut them off If mr48chev doesn't square you away.
04-27-2012, 01:15 PM | #17 | |
Re: Rear leaf mount
Yeah I apologize, I tried to be as specific as I could, but seemed I wasn't haha. If you look at the picture above you can see just a little bit of the helper spring that are on the rear leaf springs. I need the rear mount of that. From factory, I believe they came on welded. I appreciate the offer and will keep you updated. Thanks.
04-27-2012, 11:35 PM | #18 |
Re: Rear leaf mount
The ones I have are good.
Pm me your mailing address if you want them. All I ask is that you pay the price of mailing them and pay it forward at some time in the future. |
04-28-2012, 07:47 AM | #19 |
Re: Rear leaf mount
PM sent. Thanks.
04-30-2012, 08:39 PM | #20 |
Re: Rear leaf mount
I got them off and got them shipped.
This is one of the few times I took something of a frame that I was concerned with keeping in good shape. First I center punched the rivets Then I used a small drill bit as a starter OOps, this one is a bit off center. After working through about three sizes of drill bits I had it to where I could knock the tops off with the bfh and big chisel. First one After a touch up with the flap wheel I got out my old standby chisel and popped them loose. Off they came. Ready to go in the priority mail flat rate box. Off to NY The difficult part was turning the frame over to be able to work on it easily. I'll get the rest of the stuff I need to remove off while I have it flipped over and set it up for the new rear springs. |
04-30-2012, 08:41 PM | #21 |
Re: Rear leaf mount
And guess who gets to take the pins out
04-30-2012, 09:08 PM | #22 |
A320 Pilot/USAF Retired
Re: Rear leaf mount
You're a good man Mr48Chev!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
05-01-2012, 09:28 AM | #23 |
Re: Rear leaf mount
Hey Rob,
What springs are you going back with on your frame? S-10? If so I would like to see a write up on that. I have been thinking about doing that for now and come back later with a 4-link
2006 Chevy Silverado 3500(Duaramax/Allison) - DD 1997 Honda Civic - Work Beater 1981 Chevy Malibu - Race Car 1959 Chevy Truck - Project http://67-72chevytrucks.com/vboard/s...d.php?t=481442 2006 Honda Accord - Wife's ride |
05-01-2012, 09:29 AM | #24 |
Re: Rear leaf mount
With a grin ear to ear my friend.
This is a prime example of the "over and above" relationships you develop over a forum, something you wouldn't be able to explain to someone who isn't affiliated with the "car/truck scene" online. It is things like this that cease to amaze me. Rob thanks again, I really appreciate all the help. I will be PayPaling you the money today. Again, I cannot thank you enough.
05-01-2012, 10:55 AM | #25 |
Re: Rear leaf mount
In the process I discovered that drilling the tops of the rivets out progressively with good drill bits to the point where you can take a chisel and knock the head off without beating things to death works very well. Now that the frame is upside down on the saw horses the rest of the stuff that needs to be removed will get removed and I may make a bit of progress if I get the lawn mower started early and get the chores done in time to have a bit of truck time this afternoon.
